Let's say I have a pulse delay generator, an oscilloscope, and a signal generator which are tied to a 10MHz clock.
The scope has a sampling rate of 1Gs/s, so dt is 1e-9 seconds.
I have a repeatable waveform generated by the signal generator that is triggered by the pulse delay generator. The scope is also triggered by the pulse delay generator.
The first acquisition takes place, several waveforms are averaged and the data is stored.
I then take a second acquisition, but this time the pulse delay generator offsets when the oscilloscope is triggered, with respect to the signal generator by dt/2.
I then take both acquisitions and interleave them, which should have given me twice the original sampling rate.
1.) Is this method used by anyone here? I'm guessing if this works, it should only be done on equipment that can be referenced to a 10MHz clock.
2.) What is the limit this can be taken to? Would this be limited by the device with the highest jitter?
3.) If you have done this before, what scope did you use and how far above the base sampling rate could you achieve?
I understand this isn't any good for increasing the bandwidth of a scope. It's more of a niche case in which I would need to do this.
