Author Topic: Siglent SPD3303C Power Supply Channel 2 Not Floating  (Read 1283 times)
Offline HearingaidsTopic starter
« on: March 05, 2022, 06:17:44 pm »
I purchased 2 of these and one functions correctly in that both channels float. The other has channel 2’s negative terminal connected to the chassis Ground lug.
I can send this back to Siglent at some cost or try and fix it myself. I found one other case where someone else had the same problem but just returned it to Amazon. I would have done that but stupidly left it in the box until the return window was closed.
Anyway I was wondering if anyone else here had faced the same issue and whether it was an easy fix. Thx for any assistance.
Offline tautech
Re: Siglent SPD3303C Power Supply Channel 2 Not Floating
« Reply #1 on: March 05, 2022, 07:13:18 pm »
Welcome to the forum.
Good catch as this one unit does not meet datasheet spec:
https://siglentna.com/wp-content/uploads/dlm_uploads/2017/10/SPD3303C_Data-Sheet_DS0503C-E01C.pdf
P3:
Insulation: Case to Terminal: ≥20 MΩ (DC 500 V)
Contact Siglent NA and have them fix or replace it.
info@siglentna.com
« Reply #2 on: March 05, 2022, 08:30:49 pm »
I have contacted them but was wondering if it would be an easy enough fix to do myself. Thought someone else here might have see the issue.
Offline tautech
« Reply #3 on: March 05, 2022, 08:41:52 pm »
And break the warranty seal ?
Best not to but place it back firmly in their lap to sort properly and report back if it's a production issue.
But your call.........
Offline TimFox
« Reply #4 on: March 05, 2022, 08:49:48 pm »
I doubt that the factory accidentally added a wire to chassis ground, so the problem is probably a bit harder to fix:  possibly a shorted capacitor or a stray piece of metal (burr or swarf).
If you can arrange it, returning it for warranty service is probably a better idea.
Offline tautech
« Reply #5 on: March 05, 2022, 09:07:07 pm »
Or solder bridge. Not the customers job to investigate why it don't meet spec.......
« Reply #6 on: March 05, 2022, 10:34:28 pm »
Ok. I’ve been convinced. I’ll return it. Thx everyone!
