Products => Test Equipment => Topic started by: PostNubila on May 21, 2016, 02:09:50 pm
Title: ATTEN ADS 1102CAL Invalid USB Descriptor
Post by: PostNubila on May 21, 2016, 02:09:50 pm
I have a ATTEN ADS 1102CAL (with no plus sign) which have the following configuration:
Firmware version 3.01.01.31
Hardware version: 6-41-2.1
I connected it to my laptop with Windows 7 (32-bit), installed the driver and Easyscope and everything worked fine.
Now, I'm trying to connect it to another laptop with Windows 10 (64-bit) and I'm not able to install its driver.
Windows device manager shows the following:
Unknown USB Device (invalid configuration descriptor)
So, my questions are:
Have you guys experienced the same issue?
Did you find any solution?
Is it possible to install it under Windows 10 or I have to keep a laptop with Windows 7 if I want to use Easyscope?
Thank you in advance,
Stanley.
Title: Re: ATTEN ADS 1102CAL Invalid USB Descriptor
Post by: tautech on May 21, 2016, 02:18:47 pm
With Win 7 & 8 (don't know 10) you must have NI VISA installed FIRST as the USB drivers are NI supplied.
The installed driver will have a filename something like ausbtmc.inf
Find it with a search, more than likely in the installed NI directory and make sure the scopes USB properties/driver  points to that driver.
Hope that helps.
Post by: tautech on May 21, 2016, 02:27:34 pm
Attached is a doc on USB connection problems that I wrote some time ago with a link to a thread.
