As I put the finishing touches on my ATX power supply conversion, I'm still trying to sort out what I sense to be a (very) strong bias against ATX power supplies here. I'm trying to figure out to what extent the apparent bias is, well, just personal bias, and to what extent it is justified and based in fact.
Now one of the big concerns seems to be that the ATX supplies don't have current limiting, and therefore your expensive circuit can get damaged. But isn't that a bit like saying "Wrenches make crappy hammers". Well, yeah, it's presumed you know enough to use the right tool for the job, and AFAIK nobody ever claimed that an ATX supply includes current limiting. So don't use it where current limiting is important.
On the other hand, a decent ATX supply has internal protection to shut off overcurrents over their set point. As well as overvoltage and other protective elements, depending on whether it's a piece of junk or name brand that follows (or exceeds) ATX specs. As I've shown before, I've done tests to show that my supply (and presumably other name-brand ATX-compliant supplies) has supervision circuitry to instantly shut off the supply at or below rated current. No spikes (unless they last for 10mSec or less and I missed them...). So we're back to knowing the specs of your power supply and applying it appropriately. Like you do for any other piece of equipment.
So are people actually saying "never, ever, ever use an ATX power supply on your bench or else worlds will collide, and there's absolutely NO possible use case for you to ever justify using a converted ATX supply", or is it more like "yeah, they're fine when appropriate, as long as you consider their limitations, just like you do with every other piece of equipment".
Is there something I'm missing? They're fine for many gazillions of computers around the planet, and assuming you buy one with all of the important certifications and protection (unlike some of the equipment many of us use on our benches
), isn't it just a matter of making sure you don't do something dumb and apply it in the wrong situation (like on a $10,000 circuit where you need an appropriate power supply with current limiting in case you do something dumb?).
Personally, I just used mine to test/calibrate a high current sensor, while my main power supply was busy. Worked fine. Was that a mistake?
