Author Topic: AU2019 Elektor LCR Meter - 50Hz - 2MHz (upgraded AU2013)  (Read 3789 times)
Offline xfd1001Topic starter
« on: March 19, 2022, 12:34:02 pm »
Hello,
Recently fraubrj / Elektor has released a new version of the AU2013 LCR meter the AU2019.
This time it seems the files are free to download! Files include BOM, gerbers, software and seem to even include the source code this time  :)
https://www.elektormagazine.com/news/double-treat-the-new-elektor-lcr-meter
https://www.elektormagazine.com/labs/remake-lcr-meter
Specs
Has anyone reviewed or build the new version yet?
« Last Edit: March 19, 2022, 12:57:38 pm by xfd1001 »
The following users thanked this post: fps
Offline daisizhou
  • Country: cn
Re: AU2019 Elektor LCR Meter (upgraded AU2013)
« Reply #1 on: March 19, 2022, 12:56:28 pm »
Do you have plans to assemble it?
daisizhou#sina.com #=@
Offline zitoune
  • Country: sg
Re: AU2019 Elektor LCR Meter - 50Hz - 2MHz (upgraded AU2013)
« Reply #2 on: October 01, 2022, 09:27:15 am »
Yes go to the project page https://www.elektormagazine.com/labs/remake-lcr-meter#comments
Schematics, gerber files, BOM, etc.. are available; there's also a kit that is more cost effective to buy as such rather than trying to source yourself all the parts.
The following users thanked this post: dobsonr741
Offline fps
  • Country: hk
« Reply #3 on: May 01, 2023, 02:46:05 am »
If it is assembled by yourself, calibration will be a problem
Offline dibro
« Reply #4 on: May 01, 2023, 03:57:22 pm »
Calibration is no problem at all.
Download and read the manual to see how it's done.
Online pope
« Reply #5 on: May 01, 2023, 04:29:41 pm »
Very interesting. Has anyone actually built one?
Online coromonadalix
« Reply #6 on: May 01, 2023, 04:40:47 pm »
i was tempted by this project for a very long time
https://www.elektor.com/elektor-2-mhz-lcr-meter-kit
€799.00    outch  .....  1186$ CAD  ????  outch outch
but im a member
€719.00   you save €80.00  ...............  mmm
And yes  the files where made public ...
Ther was in the past  Accuhard A101  an usb  lcr meter, sadly i missed the oppurtinity to get one of the last batch,  now   website is closed  ... at 200 USD at the time .. not going into 2Mhz  i think it was 100Khz or 200Khz  ...
« Last Edit: December 06, 2024, 04:31:54 pm by coromonadalix »
Offline dibro
« Reply #7 on: May 01, 2023, 07:35:10 pm »
Yep, I did.
Offline dobsonr741
« Reply #8 on: May 02, 2023, 02:52:07 pm »
I find all downloads behind the paywall. Can you show the link to the free downloads?
Online JohanH
« Reply #9 on: May 02, 2023, 02:56:51 pm »
It's not paywalled, you only have to register and login. Schematics and all is there. The "Updates from the author" section has latest files all in one place. Well, not entirely. Latest firmware is found in comments.
I was tempted to build this for a while, but the parts become too expensive.
« Last Edit: May 02, 2023, 03:02:45 pm by JohanH »
Online kripton2035
« Reply #10 on: May 02, 2023, 05:25:15 pm »
I also found it too expensive from the beginning, and too complex too.
Offline fqahmad66
« Reply #11 on: May 05, 2023, 11:00:49 am »
Yes it is a 'Kit' Project. For accurate measuring, 1.0V test voltage is required. At lower test volt ranges, PS noise effects the accuracy.
« Last Edit: May 05, 2023, 11:04:56 am by fqahmad66 »
Offline fqahmad66
« Reply #12 on: September 03, 2023, 08:14:04 am »
Finally built one...all hardware DIY.
The following users thanked this post: coromonadalix, Martin72
Offline Sighound36
« Reply #13 on: September 03, 2023, 09:10:51 am »
I wonder how long before the Chinese have a copy for the usually Ali express plus a wee bit  :palm:
Offline fqahmad66
« Reply #14 on: September 03, 2023, 10:38:52 am »
A 2MHz LCR meter on AliExpress for cheap???
« Reply #15 on: September 03, 2023, 01:13:28 pm »
loll you never know  loll  if they can  they will
