Author Topic: Backup Firmware DG1022  (Read 16265 times)
Offline Igor_kTopic starter
« on: January 26, 2016, 12:13:34 pm »
JTAG Blackfin & Altera
« Last Edit: January 27, 2016, 12:53:39 am by Igor_k »
The following users thanked this post: ivi_yak, JimKnopf
JTAG Cable
« Reply #1 on: January 27, 2016, 01:00:02 am »
WIGGLER     Blackfin JTAG     Altera JTAG
TMS      --     TMS        --      TMS
TCK      --     TCK        --      TCK
TDI      --     TDI
                TDO        --      TDI
TDO      --------------------      TDO
WIGGLER
« Reply #2 on: January 27, 2016, 01:03:26 am »
Scheme
« Last Edit: January 27, 2016, 01:15:03 am by Igor_k »
Software
« Reply #3 on: January 27, 2016, 01:27:03 am »
Windows XP SP3
TopJTAG Flash Programmer
Setup JTAG chain
« Reply #4 on: January 27, 2016, 01:33:37 am »
JTAG chain
« Last Edit: January 27, 2016, 02:40:50 pm by Igor_k »
Setup Flash array
« Reply #5 on: January 27, 2016, 02:56:28 pm »
Flash array
Setup Signal pins
« Reply #6 on: January 27, 2016, 03:02:58 pm »
Signal pins
« Last Edit: January 27, 2016, 03:09:53 pm by Igor_k »
Read Flash
« Reply #7 on: January 27, 2016, 03:18:32 pm »
Backup Full Flash
« Last Edit: January 27, 2016, 03:24:45 pm by Igor_k »
Offline TheSteve
  • Living the Dream
Re: Backup Firmware DG1022
« Reply #9 on: January 27, 2016, 07:40:51 pm »
Nice work, thank you for the detailed post. Oh how I miss the parallel port, it was useful for so many things.
Are you also able to erase/program the various memories?
VE7FM
« Reply #10 on: January 27, 2016, 08:04:30 pm »
I will be glad if the information will be useful.
The parallel port has been selected as an example.
TopJTAG Flash Programmer support many USB cables:
Altera USB-Blaster, USB to JTAG interfaces based on FTDI FT2232 chip, e.g.
Olimex ARM-USB-TINY-H, ARM-USB-OCD and ARM-USB-TINY, Digilent JTAG-USB...
Yes.
« Last Edit: January 27, 2016, 08:33:01 pm by Igor_k »
The following users thanked this post: Kirill S
Offline Kirill S
  • Country: ua
« Reply #11 on: October 31, 2016, 01:07:41 am »
Thanks, Igor, for the detailed instructions. I've managed to flash my Atten ADS1102CAL over JTAG with J-Link cable+topJTAG Flash Programmer. There are some differences. I have Lattice FPGA on the board which controls 3 high address pins of the flash.
Could you explain what is the purpose of configuring static pins of Altera FPGA in topJTAG Flash Programmer Setup?
Offline Paul_Elec
« Reply #12 on: March 08, 2017, 09:31:49 pm »
Hi everyone,
I'm bumping this thread in the hope that the owner of an old DG1022 will be able to backup his/her firmware and let me know about it.
I desperately need a firmware PRIOR 00.01.00.04.00.02.07. I think the best one for my equipment is 00.01.00.04.00.02.03
If some one could spare some time doing this, you would make my (and other people in the same boat) day as Rigol last legacy (.ldr) firmware (00.01.00.04.00.02.03) has a bug disabling the channel 1 and they are totally helpless.
Thanks in advance,
Paul
Offline ivi_yak
« Reply #13 on: January 03, 2018, 02:18:42 pm »
hi, could it possible to load flash via jtag? i have setup seems to your and can read flash but cant to write and have error
eevblog
« Reply #14 on: January 04, 2018, 10:31:26 am »
You can read, erase and write!
Checked personally.
Offline ivi_yak
« Reply #15 on: January 04, 2018, 10:53:19 am »
finally i can write some to flash but when i start read after write ist only FFFFF.... in memory (seems empty). :-BROKE
jtag my chain is Altera EP2C5Q208 + BF531+j-linkv8 normally detected by topjtag
Maybe something wrong? If it possible Could you share your mem dump I try to load it?
eevblog
Offline JimKnopf
« Reply #16 on: May 27, 2021, 08:05:47 am »
Hello,
anyone here able to send me a backup of an 00.03.00.08.00.02.08 Version?
I tried to update using the "help" button update procedure with .GEL files. But my DG1022 doesn't stop boot process.
So i tried to update using the .LDR file via menu/recall button for older devices.
Update succeeded, it told me to restart the device. After reboot, the display is dead (illuminated but dark).
Seems the device is bricked.
I found this thread here (after the update failed). I followed the instructions and i'm able to read the flash memory as described by Igor_k.
I need a backup or maybe a unpacked .GEL update-files (bootloader and firmware) and the memory addresses where i have to put this content to.
Offline tv84
  • Country: pt
« Reply #17 on: May 27, 2021, 12:45:48 pm »
 :palm:
I don't know these equipments BUT if you say you loaded a .GEL as a .LDR file, you messed things big. Because the .LDR is a raw file designed to be loaded in the BF.
A .GEL file is a package that usually contains one or more .LDR files and others.
Offline JimKnopf
« Reply #18 on: May 27, 2021, 01:49:44 pm »
@tv84 I read your comments from 2016 and later for the DS1000Z series (very helpful thread by the way). I got a DS1054Z too.
The mentioned tools for the DS1000Z-GEL files does not work with the GEL files for the DG1022 devices.
I don't know why my device did not respond to the help button at boot time. Pressing help button did nothing. The device booted normal when pressing the help button (before the update trial). So i tought it must be one of the older devices that needs the LDR file. I did the update with the LDR file not with a GEL file.
Anyway, it will not start now and i need a backup dump. Otherwise i can try to flash the firmware and the new bootloader separatly. There is a M25X20AV 1Mbit SPI eeprom. I read that content out before i tried to update. I'm not sure if the content from the bootloader file has to be flashed to this SPI eeprom.
« Last Edit: May 27, 2021, 01:51:55 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #19 on: May 27, 2021, 02:10:12 pm »
Jim,
The files from DS are different from DG.
Here is the parsing of the 00.03.01.00.00 DG10x2Update.GEL:
00000000 - File Type: RIGOL:DG1:UPDATE FILE ALL
Offset     StartAdd  Size      LoadAddr  CRC16       Rsvd
00000040 - 000002C0  00000000  20000000  0000  0000  00000000
00000054 - 000002C0  0013F95A  20030000  403C  0000  00000000  [000002C0-0013FC19]  CRC NOT OK
00000068 - 0013FC1A  00001194  20208000  1907  0000  00000000  [0013FC1A-00140DAD]  CRC NOT OK
0000007C - 00140DAE  00001194  2020C000  532D  0000  00000000  [00140DAE-00141F41]  CRC NOT OK
00000090 - 00141F42  00004650  20210000  7712  0000  00000000  [00141F42-00146591]  CRC NOT OK
000000A4 - 00146592  00002EE0  20220000  9CD1  0000  00000000  [00146592-00149471]  CRC NOT OK
000000B8 - 00149472  0000EA60  20228000  DC3F  0000  00000000  [00149472-00157ED1]  CRC NOT OK
000000CC - 00157ED2  00007530  20250000  5105  0000  00000000  [00157ED2-0015F401]  CRC NOT OK
000000E0 - 0015F402  000005DC  20260000  1416  0000  00000003  [0015F402-0015F9DD]  CRC NOT OK
000000F4 - 0015F9DE  00070000  20290000  B748  0000  00000000  [0015F9DE-001CF9DD]  CRC NOT OK
It seems that I was never able to recreate the CRC...  |O
Here is the parsing of Bootloader_03 DG10x2Update.GEL:
00000040 - 000002C0  00019982  20000000  0000  0000  00000000  [000002C0-00019C41]
00000054 - 00019C42  00000000  20030000  0000  0000  00000000  EOF
00000068 - 00019C42  00000000  20208000  0000  0000  00000000  EOF
0000007C - 00019C42  00000000  2020C000  0000  0000  00000000  EOF
00000090 - 00019C42  00000000  20210000  0000  0000  00000000  EOF
000000A4 - 00019C42  00000000  20220000  0000  0000  00000000  EOF
000000B8 - 00019C42  00000000  20228000  0000  0000  00000000  EOF
000000CC - 00019C42  00000000  20250000  0000  0000  00000000  EOF
000000E0 - 00019C42  00000000  20260000  0000  0000  00000000  EOF
000000F4 - 00019C42  00000000  20290000  0000  0000  00000000  EOF
Don't know if this helps you extract the raw parts.  :-//
Offline JimKnopf
« Reply #20 on: May 27, 2021, 02:40:22 pm »
I just compared the content of the W25X20AV SPI chip with the content i dumped before the update. Seems this content is untouched.
# md5sum W25*.bin
9a2725ee35180f428d517cce2de1718e  W25X20AV_2_flashrom_20210527_backup-test.bin
9a2725ee35180f428d517cce2de1718e  W25X20AV_flashrom_20210524_backup.bin
Maybe the SPI flash has nothing to do with bootloader. Or the LDR file i flashed has no bootloader update inside.
« Last Edit: May 27, 2021, 02:45:08 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #21 on: May 27, 2021, 04:19:53 pm »
# md5sum W25*.bin
And how do those contents compare with the parts in the .GEL that I parsed?
Offline JimKnopf
« Reply #22 on: May 27, 2021, 08:11:49 pm »
I searched for some random content from the SPI dump in the two GEL files you mentioned. But could not find any match.
But, i also searched for longer random content from the two GEL files in my JTAG-NVRAM dump. And bingo, i found a lot of matches. I found nearly every content from the GEL file in my NVRAM-dump.
I attachted the NVRAM-dump. Hope someone with more clue than me can tell me whats wrong with my memory dump.
« Last Edit: May 27, 2021, 08:13:51 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #23 on: May 27, 2021, 08:46:42 pm »
The W25X20AV_flashrom_20210524_backup.bin file is the dump of the Altera FPGA.
Your NVRAM dump is from the BF.
Look at the Load Addresses of my parsings and the blocks I indicate there.
I think you have to load (patch) those blocks into your NVRAM dump. I would start by putting the bootloader in the offset 0x000000.
Remember that the offset 0 of the dump corresponds to 0x20000000 in the addresses table.
Offline JimKnopf
« Reply #24 on: May 27, 2021, 09:05:11 pm »
I grabbed the W25X20AV_flashrom_20210524_backup.bin of the eeprom. I desoldered (now 2 times) the eeprom an read it with my RT809H and Batronix BX48II (tried different programmer just so see if there is a different).. Maybe it's code for the Altera processor. But i read it from eeprom.
Offline tv84
  • Country: pt
« Reply #25 on: May 27, 2021, 09:19:55 pm »
One of my files is the bootloader.
You must place the blue block at the red address in the NVRAM dump! (remember that address 0x20000000 = offset 000000 in the dump)
Offline JimKnopf
« Reply #26 on: June 14, 2021, 07:30:30 pm »
@tv84 Today i tried to flash the modified ldr file. The file is attached as zip file.
I could not erase the memory before writing. After writing i could not verify it. The DG1022 does not start.
Please, can someone send me a flashdump or proper prepared ldr file for DG1022?
Offline tv84
  • Country: pt
« Reply #27 on: June 14, 2021, 08:30:01 pm »
I've asked for external help BUT you should further investigate the not being able to verify.
Because, even with a correct dump, if you can't write/verify the thing correctly, it is useless.
Offline JimKnopf
« Reply #28 on: June 15, 2021, 10:00:37 am »
@tv84 OK, i used shorter wires and reduced clock speed (1 MHz instead of 6 MHz). Writing and  verifying worked.
But the device will not start.
Offline JimKnopf
« Reply #29 on: June 15, 2021, 02:43:55 pm »
@tv84 I found out that the problem was related to the clock speed rather than wire length. The clock signal on the Segger clone becomes unstable at more than 3MHz.
Offline JimKnopf
« Reply #30 on: June 21, 2021, 06:45:01 pm »
@tv84 Any idea why i can't programm the address space 0x0000 - 0x3fff? When i programm the nvram via jtag, the mentioned area is empty.
I tried different programmers now: TIAO Tumpa, Olimex Tiny-H, Segger j-link clone. Always the same result.
Offline JimKnopf
« Reply #31 on: August 06, 2021, 07:21:55 pm »
@tv84 How can i move data from 0000 02C0 - 0001 9C4 to 2000 0000 in NVRAM dump when the file ends at  003F FFFF?
« Last Edit: August 06, 2021, 07:33:57 pm by JimKnopf »
Offline JimKnopf
« Reply #32 on: August 07, 2021, 07:26:42 pm »
That's good news. I'll try to get some help.
Till now i couldn't figure our why i cannot write to  0x0000 0000  - 0x0000 3fff via jtag. Hint's are welcome.
Anyway, i desoldered the 4MB S29GL032N 48 pin flash memory and programmed it in my RT809H using an 48-pin adapter.
I have to say that this is way faster than waiting 40 minutes when programming via jtag.
Desoldering with low melting solder (Chemet Bi57Sn43) took less than 2 minutes, cleaning and preparing the solderpads with new solder took 2 more minutes.
Erasing, programming and verifying the data took less than 5 minutes. Soldering back the Chip was pretty easy.
I did this in less than 20 minutes, half the time i need to programm the flash via jtag. And soldering looks better than factory.
@tv84 The 52 49 ... data  from the file now starts at 0x0000 0000 in the flashmemory (loaded at 0x2000 0000 for BF531).
But the device still doesn't start.
Would be great ff anyone could support me with a memory dump for a DG1022, Version 00.03.00.08.00.02.08.
Offline tv84
  • Country: pt
« Reply #33 on: August 09, 2021, 09:19:36 pm »
Jim,
I corrected the first 0x130 bytes of your dump (they were totally wrong).
Attached is the corrected .bin you should flash. Even so, the file missed some important areas.
I include also its Blackfin .LDR parsings to validate that the contents of this dump is sound and should allow the device to boot.
« Last Edit: August 15, 2021, 03:35:51 pm by tv84 »
Offline JimKnopf
« Reply #34 on: August 15, 2021, 10:48:26 am »
@tv84 Thank you alot for your effort. The device starts with your modification.
I can see the button lights at boot sequence and hear the relais after booting.
I can recognize the device via USB on Linux and it show up on UltraSigma in my Windows-VM.
The display will not turn on. It flashes one time when pressing power button and goes dark.
After booting up when pressing "View" button, the button itself lights up but display remains dark.
I can't use it with UltraSigma (maybe Softwareproblem, not a device problem?).
Offline JimKnopf
« Reply #35 on: August 15, 2021, 03:29:02 pm »
@tv84 It was 00.03.00.08.00.02.08 when i tried to update.
00 Bootversion
   .03 Hardware revision
        .00.08 FPGA version
                  .00.02.08 DSP version
Offline tv84
  • Country: pt
« Reply #36 on: August 15, 2021, 03:31:06 pm »
Try this one from a working unit with your settings, crafted by me.
This one was extracted from a 00.03.00.08 machine also running FW 2.08. So I'm confident it must work.
Report the results.
« Last Edit: August 15, 2021, 03:39:44 pm by tv84 »
The following users thanked this post: JimKnopf
Offline JimKnopf
« Reply #37 on: August 15, 2021, 05:07:57 pm »
@tv64 Many many thanks for your patience and effort. The device works.
It shows up the correct serial number.
« Last Edit: August 15, 2021, 05:29:35 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #38 on: August 15, 2021, 06:23:56 pm »
The device works.
 :popcorn: Show us the screenshot with the HW and FW version just for future reference.
Offline JimKnopf
« Reply #39 on: August 15, 2021, 06:37:44 pm »
@tv84 Interesting, the Version number show some crap.
What is the best way to update this device? Using  a LDR file or with a GEL file?
The bootloader has to be updated first.
Offline tv84
  • Country: pt
« Reply #40 on: August 15, 2021, 06:48:45 pm »
Interesting and that could be helpful for my investigations. -> EDIT: There are 20 bytes (I think they are not very important) that were wrong in the dump you provided and that I unknowingly reused, but should be corrected in order for the HW/FW version to look correct.
So, that allowed me to discover where the .GEL contains the FW version.
Here is the parsing of the 2.10 FW as an example:
Offset     StartAdd  Size      LoadAddr  CRC16       Rsvd                           CRC16_calc
00000054 - 000002C0  001B4BC0  20030000  0000  0000  00000000  [000002C0-001B4E7F]  DBE0
00000068 - 001B4E80  00001194  20208000  0000  0000  00000000  [001B4E80-001B6013]  1907
0000007C - 001B6014  00001194  2020C000  0000  0000  00000000  [001B6014-001B71A7]  532D
00000090 - 001B71A8  00004650  20210000  0000  0000  00000000  [001B71A8-001BB7F7]  7712
000000A4 - 001BB7F8  00002EE0  20220000  0000  0000  00000000  [001BB7F8-001BE6D7]  9CD1
000000B8 - 001BE6D8  0000EA60  20228000  0000  0000  00000000  [001BE6D8-001CD137]  DC3F
000000CC - 001CD138  00007530  20250000  0000  0000  00000000  [001CD138-001D4667]  E68F
000000E0 - 001D4668  00000590  20260000  0000  0000  00000003  [001D4668-001D4BF7]  5C1C
001D46A8 - FW Version: 00.02.10.00 - RIGOL TECHNOLOGIES,DG1012C,DG1F
000000F4 - 001D4BF8  00070000  20290000  0000  0000  00000000  [001D4BF8-00244BF7]  B343
Regarding upgrade, AFAIK 2.08 can't be upgraded (see attached file). I suppose it must be because of the bootloader.
So, my suggestion would be, I can create an image  based on a 2.10 dump. Then you flash that image.
Then you can execute upgrade to version 2.12.
Or, first, you try to upgrade to 2.10 with the stock GEL only and see if you can make it work.
« Last Edit: August 16, 2021, 08:24:16 pm by tv84 »
Offline JimKnopf
« Reply #41 on: August 16, 2021, 06:49:17 am »
@tv84 Where did you got this information from? The official Rigol release notes confused me when i tried to update because my device never displayed such a long 10 digit DSP version number.
They advised in their release notes:
    IF you have a DG1022 read this:
     1) If the version is < 00.03.00.08.00.02.08.00.01 then you can only update using the LDR version.
         Then you MUST use the LDR file and the instructions in “DG1022 Legacy LDR Update
         Instructions”.
Does version number 00.03.00.08.00.02.08 means < 00.03.00.08.00.02.08.00.01? Or is it the mentioned version number but some digits are just missing on the display?
I took the attached image before the update.
Offline JimKnopf
« Reply #42 on: August 16, 2021, 11:42:12 am »
@tv84 I can't update the regular way. Maybe because of the strange version number?
« Last Edit: August 16, 2021, 12:13:35 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #43 on: August 16, 2021, 12:36:45 pm »
Most probably. I suspected that.
Do you want me to create a 2.12 version with boot 3?
I think that would allow to flash a stock 3.01.00 FW directly.
« Last Edit: August 16, 2021, 12:39:04 pm by tv84 »
Offline JimKnopf
« Reply #44 on: August 16, 2021, 12:38:41 pm »
@tv84 That would be great. I would give it a try.
Offline tv84
  • Country: pt
« Reply #45 on: August 16, 2021, 12:41:01 pm »
But you"ll have to flash with programmer, ok?
Offline JimKnopf
« Reply #46 on: August 16, 2021, 01:02:15 pm »
@tv84 I have done this about 10 or 12 times now with this chip. I ordered some new S29GL032N90TFI04 flash chips because I think the chip will die eventually. At some point it will have been too much. Even if you are skilled, once, twice or three times you can do it with a TSOP48 flash chip. But the chip can't take that much heat. And the more often you do it, the worse it sits in the programming socket. Solder residues remain on the legs and lead to contact problems in the socket.
Offline tv84
  • Country: pt
« Reply #47 on: August 16, 2021, 07:06:03 pm »
Just for future reference, and because Rigol instructions are not very clear, what Rigol calls the .LDR file (attached) is a file that loads (IMHO) the 00.02.07.00 FW version.
So, anyone with a higher version should never flash this one. I think this was JimKnopf's initial mistake.
Offline JimKnopf
« Reply #48 on: August 16, 2021, 07:32:47 pm »
@tv84 I think i tried a LDR file but it was a different one. I checked the LDR files i have and compared the md5sum against the file you attached:
find ./ -name '*LDR*.zip' -exec md5sum {} \;
c30ee29b93dc6bddb540b385c1b6be5b  ./examples/tv84/DG10x2_Update_Last_LDR.zip
876a1d457f5f3e77aeddd8290bd02270  ./DG10x2_Update_Last_LDR_00.02.07.00.zip
c30ee29b93dc6bddb540b385c1b6be5b  ./dg1000_latest/LDR/DG10x2_Update_Last_LDR.zip
c30ee29b93dc6bddb540b385c1b6be5b  ./dg1000_/DG10x2_Update_Last_LDR.zip
I have the latest LDR file from Rigol website.
Offline tv84
  • Country: pt
« Reply #49 on: August 16, 2021, 07:38:59 pm »
My ZIP contains a parsing of the .LDR made by me. :)
You should not compare the ZIPs but the LDR inside.
Offline JimKnopf
« Reply #50 on: August 16, 2021, 07:44:08 pm »
@tv84 Oh, i see. I was too quick. I extracted the files:
find ./ -name '*.ldr' -exec md5sum {} \;
698cd8eb479c8dce5b85e9478ae098ac  ./examples/tv84/DG10x2_Update.ldr
a1d5cd44227fe07e44de9d6e6b0dde7f  ./examples/tv84/bootloader-tv084-v1.ldr
698cd8eb479c8dce5b85e9478ae098ac  ./DG10x2_Update_Last_LDR_00.02.07.00/DG10x2_Update.ldr
698cd8eb479c8dce5b85e9478ae098ac  ./dg1000_latest/LDR/DG10x2_Update.ldr
698cd8eb479c8dce5b85e9478ae098ac  ./dg1000_/DG10x2_Update.ldr
Indeed it's this LDR file i tried.
Offline tv84
  • Country: pt
« Reply #51 on: August 16, 2021, 08:09:39 pm »
Here is the flash dump that should give you FW 02.12.00 with Bootloader 03 already included.
It should allow for a direct stock 00.03.01.00 .GEL flash (which I think is the latest AFAIK).
Try and report.
Edit: removed file as it was not OK.
« Last Edit: August 17, 2021, 06:42:04 pm by tv84 »
Offline JimKnopf
« Reply #52 on: August 17, 2021, 10:08:02 am »
@tv84 I programmed the flash memory and tried to boot. All illuminated buttons light up, device will not start.
Offline tv84
  • Country: pt
« Reply #53 on: August 17, 2021, 06:41:21 pm »
Jim,
Version 2.10 with your settings. Extracted from a working unit.
Test and report.
Offline JimKnopf
« Reply #54 on: August 18, 2021, 05:45:56 pm »
@tv84 Thanks again.
The device booted with your latest firmware file. To speed things up, i build an adapter with flying wires soldered to the pads on the board and to 2x 24-pin-headers. Now i can switch the TSOP48 programming socket from the programmer to the adapter quickly without solder/desolder the chip every time.
I tried to update the bootloader using the menu. But i couldn't recall a GEL file. I did it like mentioned here:
https://www.eevblog.com/forum/testgear/rigol-dg1022-how-to-update-the-firmware/msg592701/#msg592701
After updating the bootloader, the device won't start. I just did the same proceding with the firmware update GEL file and the device started.
The only thing was, some keys were locked. I fixed it like mentioned here:
https://www.eevblog.com/forum/testgear/rigol-dg1022-how-to-update-the-firmware/msg3261146/#msg3261146
I just put a USB-Stick with the unlock.scpi file into the device and used the recall function. After that, the keys working normal.
Maybe i have to recalibrate the device.
Many thanks for your effort.
@tv84 I attached the latest NVRAM dump after updating.
« Last Edit: August 18, 2021, 09:25:25 pm by JimKnopf »
Offline tv84
  • Country: pt
« Reply #55 on: August 18, 2021, 07:02:07 pm »
Jim,
 :clap:  I was hoping for you to solve the rest!  :)
Now, update to 03.01 and send me the new dump. You used 03.00.  ;)
Offline JimKnopf
« Reply #56 on: August 18, 2021, 07:19:55 pm »
For sure I downloaded and installed the latest version DG1022X(DSP)Update(Normal)_00.03.00.00.01 from the Rigol site.
Offline tv84
  • Country: pt
« Reply #57 on: August 18, 2021, 07:23:13 pm »
Nope, this is the latest.
Offline JimKnopf
« Reply #58 on: August 19, 2021, 09:25:23 am »
@tv84 Ok, i didn't notice that there are several sources on Rigols sites with different "last" versions:
rigol.eu
rigolna.com (03.00 is the last version)
rigol.com (03.01 is the last version)
I updated without errors to 03.01.
Offline tv84
  • Country: pt
« Reply #59 on: August 19, 2021, 06:38:26 pm »
 :-+  Thread closed.
