Author Topic: Any decent power supplies with Ethernet? (Or USB)  (Read 2948 times)
Offline 0x00Topic starter
« on: January 15, 2017, 05:18:22 am »
Looking to get a power supply that I can do a bit of scripting with, most likely Ethernet (USB would be fine too).
Ideally I'm looking for something that's under $200 and has >2 outputs.
Any suggestions?
Online H.O
Re: Any decent power supplies with Ethernet? (Or USB)
« Reply #1 on: January 15, 2017, 09:20:40 am »
Voltage? Current? Power?
My guess is that $200 is a bit on the low side for a programmable supply with 2 or more channels but it'll be interesting to see what others might come up with.
The Rigol DP832 will set you back $400 and the communication (USB and LAN) option/license is another $100 if you don't want to use the available keygen to unlock it yourself.
Offline mrpackethead
  • D Size Cell
« Reply #2 on: January 15, 2017, 09:25:18 am »
Theres a nice kitset project being promoted right now on crowdsource and also in thsi forum
« Reply #3 on: January 15, 2017, 04:32:54 pm »
The EEZ H24005 and Rigol DP832 are about the same price at ~$400, seems like the Rigol is a better deal for the specs?
I don't have any hard set requirements, it's for my home setup.
Online nctnico
« Reply #4 on: January 15, 2017, 05:57:00 pm »
At the moment there are lots (loads) of GW Instek GPD-3303S programmable power supplies on Ebay. My target price is $35 but the current going price seems to be around $110.
  • D Size Cell
« Reply #5 on: January 15, 2017, 06:02:57 pm »
The HZ H24005, looks like it would give you considerably more power, and the ability to get up to 80V if you wanted.
« Reply #6 on: January 15, 2017, 06:37:52 pm »
SPD3303X-E $389
http://www.siglentamerica.com/pdxx.aspx?id=1393&T=2&tid=17
Offline eeviking
« Reply #7 on: January 16, 2017, 04:41:12 pm »
Siglent SPD3303C is 289$
No ethernet, but USB
http://siglentamerica.com/pdxx.aspx?id=174&T=2&tid=17
