I'm thinking about getting a benchtop electronic load like an itech 8511A+ or Rigol DL3000. Most electronic loads are specified with a minimum voltage at two different ranges: something like 0.14V @ 3A or 1.4A @ 30A. If I'm on the 30A range, will I be able to get to a lower voltage if I'm below the rated current (i.e. 0.7V @ 15A)? Has anyone tried this?
