Author Topic: Batronix BXM98P, Amprobe AM-510 or EXTECH EX330  (Read 12802 times)
Offline metRo_Topic starter
  • Country: pt
Offline Lightages
  • Canadian po
Re: Batronix BXM98P, Amprobe AM-510 or EXTECH EX330
« Reply #1 on: February 16, 2013, 09:27:50 pm »
The Batronix is a Victor VC9806+ or 9807+. I have a Victor VC9806+ and it has held its accuracy for two years now when compared to a DMMCheck. It is not safe for mains use as it uses little glass fuses for its current protection and the circuit board design does not meet its CAT ratings. However for the price it is a decent meter for electronics use and seems to be high accuracy for the price.
The Amprobe AM-520 has been reviewed here on the forums and it looks like a good safe meter for general electrical work with good features. The AM-510 has lower accuracy than the Batronix/Victor meter but it is built much better for safety and I would prefer to have it as a general meter than the Victor.
The Extech EX series have been demonstrated many times, here on this forum and other places, to be less than well built in in some cases dangerously so with parts falling out on the inputs. I would stay away.
In short, get the Amprobe and have a good safe meter that should serve you well for anything you might want to do, and later if you need a higher accuracy meter you will know what you want. The Amprobe will last much longer than the other two IMHO.
Offline Wytnucls
« Reply #2 on: February 16, 2013, 09:33:21 pm »
Yep, I would also go for the Amprobe, for the same reasons, adding that manual ranging only on the Batronix would be a pain in the proverbial behind.
Offline ddavidebor
    • Smartbox AT
« Reply #3 on: February 16, 2013, 11:14:59 pm »
i like the amprobe. we've some in school and they do very well done meter!
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline FenderBender
    • The Solid State Workshop
« Reply #4 on: February 16, 2013, 11:35:18 pm »
I have two Amprobe meters. I like them both a lot. I'm sorry I cannot speak for the others.
  • Country: pt
« Reply #5 on: February 17, 2013, 12:44:52 am »
Thanks for your opinion :) Amprobe looks a good choice:)
You said that Amprobe AM-520 has high accuracy but look at the overview http://www.amprobe.com/amprobe/usen/Multimeters/AM-500-Digital-Multimeter-Series/AM-510.htm?PID=74033 it look that they have the same accuracy :s
Sorry my english:/
Offline Lightages
  • Canadian po
« Reply #6 on: February 17, 2013, 01:04:24 am »
I can see why you might think I said the 520 was higher accuracy and that is my fault for my wording. The AM-510 has lower accuracy than the Batronix, is what I meant to say. The review of the 520 was to show the quality inside these meters. It is believed that the AM-5X0 series is made by Uni-Trend, but it is not confirmed. If it is so, I wish Uni-T had taken the design that Amprobe wanted and applied it to their own brand so we could enjoy things like a Uni-T UT71D with proper input protection.
Either way it is clear the AM-510, 520, or 530 are good meters from their construction.
« Last Edit: February 17, 2013, 05:57:59 pm by Lightages »
Offline T4P
  • Country: sg
    • T4P
« Reply #7 on: February 17, 2013, 03:25:16 pm »
Sorry my english:/
@mechatrommer
Another one!  :palm:
  • Country: pt
« Reply #8 on: February 17, 2013, 04:44:43 pm »
the purpose for the multimeter is electronics, low voltage and low currents so the protection for main voltage isn't something important.
Offline Lightages
  • Canadian po
« Reply #9 on: February 17, 2013, 06:09:59 pm »
Well if you are only going to use it for electronics, and won't use it to test anything over 300V, then I suggest you get a Uni-T UT61E from Franky here on the forums, his user ID here is iloveelectronics and he sells the UT61E here for a really good price with shipping included  https://www.eevblog.com/forum/buysellwanted/brand-new-uni-t-ut61e-for-sale/
It is high accuracy, 22,000 count, but has no temperature nor back light. It does come with a PC connection and logging software though. The Batronix does not have temperature, so I assume you do not care. If you think you might use the multimeter for doing anything on mains then I would suggest you think about the AM-510 instead as it is much safer for testing high energy circuits.
  • Country: pt
« Reply #10 on: February 17, 2013, 08:28:02 pm »
At maximum I'll measure the 230V main voltage. There are any review of the multimeter here in the forum? thanks :)
alm
  • Guest
« Reply #11 on: February 17, 2013, 08:37:08 pm »
Not sure if I'd trust the UT-61E with mains. A lot has been written about the UT-61E on this forum, I'm sure there are some reviews in there. Try this thread, for starters.
Offline Wytnucls
« Reply #12 on: February 17, 2013, 09:15:10 pm »
Like a majority, if not all UNI-T meters, input protection on the 61E is very basic, but not much is likely to happen while measuring mains around the house. A blown fuse at most.
A bit of long shot, but the Fluke 15B is pretty good as a first meter. Reasonably priced and well built, with decent features and good protection:
http://www.ebay.com/itm/Fluke-15B-2-6-LCD-Digital-Multimeter-Meter-/310550622295?pt=LH_DefaultDomain_0&hash=item484e427057
http://techno-mind.ru/files/fluke_15b_17b/fluke_15B_17B_user_manual.pdf
« Last Edit: February 17, 2013, 09:34:41 pm by Wytnucls »
Offline Lightages
  • Canadian po
« Reply #13 on: February 17, 2013, 11:20:01 pm »
I would trust the UT61E on 220/240 mains from the wall in a house. I would not trust it any higher voltage and not at the main panel.
Wytnucls has a good suggestion for the Fluke, but be aware it does not have frequency measurement. It will be safer for mains than the UT61E but so will the AM-510 which has close to the same accuracy as the Fluke but also has many more features.
So the choice as I see it is the UT61E with TRMS (AC only), high accuracy and counts, wide frequency measurement, PC connection included, no back light, no temperature, horrible burden voltage, and low safety for high energy circuits.
or
Amprobe AM-510 with no TRMS, lower accuracy, has back light, I see now the 510 does not have temperature too, no PC connection, slow continuity tester, no idea on the burden voltage, but high safety on higher energy circuits, plus flashlight and non-contact voltage tester.
IMHO, if you are going to be sticking the probes in the wall all the time then get the Amprobe. If you are going to be using the meter mostly on electronics and only are going to check the mains once in a while to confirm power is getting into a piece of equipment then get the UT61E.
Or if you want to spend a bit more money and have something well built and to do anything with confidence:
http://www.tme.eu/en/details/bm257/portable-digital-multimeters/brymen/#
or better yet from our friend here on eevblog, iloveelectronics on his ebay store:
http://www.ebay.com/itm/Brymen-BM257-Digital-Multimeter-6000-count-Brand-New-Fluke-alternative-/200874532840?pt=LH_DefaultDomain_0&hash=item2ec50e1fe8
« Last Edit: February 18, 2013, 12:59:18 am by Lightages »
