Hi Guys,
want to share something... No rocket science, no nobel price worthy thing, just a quick useful hack.
I don't want to pull out my old R&S HMO everytime I want to do a quick curvetrace.
So I made a small hack with the Magnova:
I connected the AWG directly to CH3 which then connects to a 1kOhm resistor and the other side of the resistor goes to CH4 and DUT+ connector. DUT- connects to GND.
Together with a bit of Python Hacking this get's a nice Curvetracer. If Math mode would work in X/Y mode it would also work directly in the scope.
The Python script simply continously reads out CH3 and CH4, applies basic math (no calibration applied or so) and plots it continoulsy on the screen.
Framerate is about 3..5 FPS.
Attached .zip contains the python code. Not a beauty, but does it's job well enough.
Data:
- short circuit protected to 10mA
- +-10V exitation amplitude, +-10mA current range
- be careful, don't inject voltage or so into your scope. E.g. don't connect a charged capacitor to it!
- It is not galvanically isolated! DUT- is directly connected to scope GND
Best regards,
Kai
- The real beauty is, that it enables also to output curvetrace raw data to e.g. excel for further analysis. Hameg does not allow that.
- This simple concept will likely work with other scopes too
