Author Topic: Battery pack for Rigol DS1054Z  (Read 41699 times)
Offline maukka
Re: Battery pack for Rigol DS1054Z
« Reply #75 on: November 27, 2017, 06:53:20 am »
Anyone tried the Omnicharge and its HVDC output (US version 150V, EU 300V) to power the DS1054Z? I've powered several SMPSs with the 300V DC with no problems, but haven't dared risk the scope yet, since I don't know whether the rectifier diodes can handle a continuous high voltage for prolonged periods.
Online Fungus
« Reply #76 on: November 27, 2017, 09:44:24 am »
Wow, that's quite an environment for it. It'll be interesting to see how you go about waterproofing it.
Seal the fan opening ?  :o  :-DD
« Last Edit: November 27, 2017, 09:56:49 am by Fungus »
Offline Diosol
« Reply #77 on: November 27, 2017, 06:36:19 pm »
Liquid cooling. :-+
Now liquid cooling is not a bad option. Very small radiator inside case and circulate fan air somehow from side to side. The liquid could be 0W-40 motor oil and pump could be some tiny 24 V fuel pump. Why oil and not glycol water? Well, I just like to keep them separate if possible from 230 AC.
I seem to like 24 and 48 VDC stuff. Industrial legos are quite fun to do projects with. I thought that small heating pad from truck mirror could bring the machine always to normal operating temperature. Yeah I'm also thinking of possibly using this in freezing cold and getting rid of moisture.
For sealing the front I haven't yet figured any good solution. Maybe just pour thin silicone layer on top of everything. I already have dedicated pelican case for this and ready to be modded.
Offline victagayun
  • Country: sg
« Reply #78 on: July 18, 2020, 04:52:38 pm »
My DS1074Z got spoilt. I think it is the power supply.
Saw some light coming from the back, now it wont power up.
Do anyone of you got info on the voltages of the pins?
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #79 on: November 11, 2020, 12:49:37 am »
sorry friend for being 3 years late. but late is still better than never right?... found this while searching for DS1052E PSU schematics. see attachments. to conclude.. rails needed for DS1054Z..
1) 9V
2) 5V
3) ±7.5V
4) ±17.5V
6 rails total...
Uncle Bob: "so what's our plan?"
Uncle Jack: "to make a plan."
Offline S. Petrukhin
  • Country: ru
« Reply #80 on: November 15, 2020, 05:06:30 pm »
As variant
And sorry for my English.
Offline shaztech_info
« Reply #81 on: January 31, 2021, 01:48:39 pm »
I created a "3d printed clip" to power the DS1054Z with 3x 20V worx (power tools) batteries. Easy to swap and charge. Last about 4 hours with 1.5Ah batteries.
No circuit needed, batteries are plugged in series (60V total).
You can print your own or modify it to fit other brand batteries (not the type with the long neck... ex: Ryobi)
Check it here :)
https://www.thingiverse.com/thing:4744634
The following users thanked this post: Zero999, Trader
Online McBryce
« Reply #82 on: February 11, 2022, 12:57:28 pm »
head up for my Battery Powered PSU for Portable Rigol DS1000E/Z to thread followers, cheers.
That link gives me a 404 error.
McBryce.
Online Mechatrommer
  • Country: my
« Reply #83 on: February 11, 2022, 01:45:37 pm »
duh.. deleted and corrected.. thanks McBryce for highlighting... head up for my Battery Powered PSU for Portable Rigol DS1000E/Z to thread followers, cheers.
Offline m3vuv
« Reply #84 on: April 29, 2022, 01:30:59 pm »
have you a link to the vid from dave mentioned?
Offline m3vuv
« Reply #85 on: April 29, 2022, 06:45:28 pm »
I have a 48v battery on my homebrew e bike,does that mean if i connect my scope mains power cable to that it will work?.,or best hook it upto the mains filter cap,ie output side of the psu bridge rectifier?.
Offline metrologist
« Reply #86 on: April 29, 2022, 07:44:10 pm »
I was going to suggest e-bike or hoverboard Li-ION packs could work.
Offline m3vuv
« Reply #87 on: April 29, 2022, 10:41:57 pm »
so long story short could i hook my scope upto my 48v ebike battery using the scopes mains cable and have it work without letting smoke out of it?,mine is a rigol DS1052D
