Author Topic: Beckman 3020 resistance readings off  (Read 693 times)
Offline TimeBanditTopic starter
« on: October 06, 2019, 09:43:16 pm »
I have a Beckman 3020 DMM that's reading about 1 ohm high. I've tested different probes, cleaned the jacks with Deoxit, checked the precision resistors inside (they're within spec), and next plan to carry out the calibration procedure (feed 190mV DC and adjust the rheostat to match while set to the 200mV range). What else am I not thinking of?
Offline retiredcaps
Re: Beckman 3020 resistance readings off
« Reply #1 on: October 07, 2019, 01:10:08 am »
When you short your probes together, what do you get?
1 ohm high when measuring what?  1 ohm high when measuring a 10 ohm resistor?  1 ohm high when measuring a 100 ohm resistor?
« Reply #2 on: October 07, 2019, 11:42:15 am »
It's behaving now, though I'm not sure why. I did notice that the negative battery wire had a bad solder connection to the double-sided board.  :-//
