How so? Eats tips?
I use the same iron (WSP80), which is why I'm curious.
Hi nanofrog,
I'm afraid it does and barrels which cost £10.00 a go and the tips are £5.00 each, also the tips are short in length.Good iron though but too expensive to run.The new Antex 660A tips are only £2.50 each and they last upto 4x longer.
The Bosnian made ones seem to be all over the place (QC issues), but they do seem to have gotten better recently (newer production apparently has their P/N etched into the butt end).
Fortunately, there are 3rd party alternatives as well
, such as
Plato/Techspray (direct link to MS series), and there are even Chinese made equivalent tips out now (
Australian sellers on eBay.co.uk). Both are less expensive here in the US, so hopefully the savings will carry over in the UK as well. Not sure of the best place to source Plato in the UK, but Mouser carries them, and Newark stocks a few as well.
As per barrels, I've not found a 3rd party supplier for those yet, but I suspect they do exist (tech from the WSP80 & WD1 have been copied now). You might also luck up on a clearance sale (I managed to get barrels under $2.00 each this way IIRC). I try to stock up on consumables when there's a sale whenever possible.
BTW, is there a setback feature in that power unit (timer)? And can it be used with the switched iron holder (WDH10T or WDH20T)?
Definitely helps extend tip life beyond what tinning alone can manage.
