theYep, so you have to set the
sampling_period for the calculation of the number of samples in the sliding STD (for the optimal tau=30-40secs), and/or for the ADEV calc properly.
Sampling_period of ie. 10PLC may have ie. 4 values as Kleinstein wrote above.
A note on the tau (why the tau in seconds is important when talking STD) and other ADEV stuff for younger makers here:Example:
I have my HP3458C set properly, I have my ideal DUT say 10V reference based on an LTZ3000.
I set the 10PLC and I knew the sampling_period (ie. for 50Hz mains, AZ ON) and I set it properly for ADEV calc, I ran the measurement over night, I got many thousands of samples with nice values around those ideal 10V.
Off the TestController I got a nice ADEV graph.
Now, I want to know what the f...ing ADEV and those taus are about and how are they related to the "stability" of my meter.
Let say I want to make (anytime) a first voltage reading with my setup "now", and the second one in a) 3 seconds after, or in b) 40secs after, or in c) 1hour after the first one reading.
Thus I want to know how is the stability of my DMM between two readings which are some time apart.
So I look into the ADEV graph and I see for example:
a) the sigma(3) (std at tau=3secs) is 400nV
b) the sigma(40) (std at tau=40secs) is 150nV
c) the sigma(3600) (std at tau=3600secs) is 800nV.
How to interpret that (with a little bit simplification, ie. neglecting the ADEV error bars)?
a) it says that ".. 68.3% of any two readings made 3 secs apart will fall into an interval 10V+/-400nV.."
b) it says that ".. 68.3% of any two readings made 40 secs apart will fall into an interval 10V+/-150nV.."
c) it says that ".. 68.3% of any two readings made 3600 secs apart will fall into an interval 10V+/-800nV.."
Why 68.3% there ?? Because the +/-1 sigma covers 68.3% under normal distribution curve (
aka STD in Vrms).
I want to have it in peak-peak voltage!!
Then (ie. gaussian noise):
a) it says that ".. 99.9% of any two readings made 3 secs apart will fall into an interval 10V+/- (3.29*400nV).."
b) it says that ".. 99.9% of any two readings made 40 secs apart will fall into an interval 10V+/- (3.29*150nV).."
c) it says that ".. 99.9% of any two readings made 3600 secs apart will fall into an interval 10V+/- (3.29*800nV).."
Why 3.29 there ?? Because the +/-3.29 sigma covers 99.9% under normal distribution curve.
And what about the "noise"?? Where is the lowest noise in the above ADEV result??
The lowest noise is at tau=40secs, because the 68.3% of any two readings made 40secs apart fall into an interval with the lowest spread (only +/-150nV). So the lowest noise with the STD=150nVrms is at the tau=40secs.
And I want that noise in peak-peak Volts!
150nVrms*6.6=990nVpp for tau=40secs.
