Multimeter ic usualy has some max voltage, to display max value.
If you would put 100V directly of its input it would maybe destroy device or give overlod signal.
Thats just a way, to attenuate the signal.
Yes, I understand that thank you, all multimeter have attenuation/gain stage in oprder to match the range full scale to the A-to-D scale. I am talking about bench DMMs with dot matrix display (so the display is not limited to a number of digits). Perhaps I need to clarify:
Advantage/Disadvantage of multiple counts within a specific decade as opposed to a fixed number of counts.
For example handheld multimeters tend to be fixed on 20000 counts. Therefore range maximums are 199.99mV, 1.9999V, 19.999V, 199.99V and so on.
I have seen a DMM with both 100000 count and 300000 count ranges, so a measured voltage will (more likely) fall within a better range?
