I will second the suggestion to provide high quality teardown _pictures_ - Hugoneus, I _love_ TSP, mostly for the fact that it allows me to peek into devices that are too expensive for most other people to open up. And I'm very thankful for your work! I know TSP must be an even larger time sink than it is a money sink, so it feels really bad to give a suggestion that would require you to spend even more time on it.
For example in the MDO4000C review, you did a full teardown, but then the resolution of the video wasn't good enough to identify a few parts that I always wanted to know what they are ("unpopulated mystery device" in
https://photos.google.com/share/AF1QipO476qh31x8zEEjAioZGXwLE8N_c5yuo6B3rg4k55-MQk-gu35gzyiasX5_aQCPfw/photo/AF1QipNmGJ5eG6rrdl6JyVaks7f8WoFbTegYycS1BEzu?key=OXR1c0VUdEdEOU45aG5QdmdId1hLejNCOWRqS3ln - based on the housing I suspect it to be a clock generator?).
Pretty likely a photo of the board in the same setup would have been sufficient (and would provide an excellence archive for repairs), as I failed really hard to image-process this from the video - the resolution just isn't there.
But then, if I had to chose between better teardown pictures at the cost of fewer TSP episodes (or Hugoneus becoming pissed at us because eevblog forum people behaving as ungrateful pricks
) - let's not focus on this too much.
