Author Topic: Part ID on a Bruel & Kjaer conditioning amplifier 2690-0S2  (Read 1370 times)
Offline JwallingTopic starter
  • This is work?
Does anyone recognize what connector this is on the power input? The manual states it's a TNC connector, but the picture in the manual does not match what's on the unit I'm working on. The attached picture is what's on mine.
Thanks!
Jay
System error. Strike any user to continue.
Offline xmo
Re: Part ID on a Bruel & Kjaer conditioning amplifier 2690-0S2
« Reply #1 on: May 20, 2018, 03:30:56 pm »
It looks like a Lemo connector.
The following users thanked this post: Jwalling
  • This is work?
« Reply #2 on: May 20, 2018, 06:33:30 pm »
Thanks, that's it! Boy, there's a billion different ones. I opened up the unit and was able to see a part # ERA.00 After spending some time on Mouser and looking at the datasheet, I think I found it's mate:
https://www.mouser.com/ProductDetail/736-FFA00250CTAC27
Not cheap...
Jay
Offline xmo
« Reply #3 on: May 20, 2018, 08:19:20 pm »
I have one of the Nexus conditioning amplifiers.  I was cheap and replaced the power connector with a round one I had on hand.
Actually, I bought a couple of the Nexus units (used).  I wanted one to use as a mic pre-amp for a test setup to measure and compare communications headsets.  I did buy the Lemo connectors for the mic pre-amp inputs so I could make up the input cables.  One cable from Brüel & Kjær would cost as much as I paid for the unit.  Installing those Lemo connectors will test your soldering and mechanical skills
I did learn a few things.  You can't just mix & match parts from a couple of broken ones to make one good unit.  They do warn you in the brochure:  "To reduce the cost of the instrument and to ensure accuracy and reliability, modules must be replaced at Brüel & Kjær."
Offline b_force
    • One World Concepts
« Reply #4 on: May 20, 2018, 09:10:07 pm »
I think Brüel & Kjær is almost known of using awkward connectors.
I used to work with acceleration meters.
The pre-amplifiers had such weird COAX connectors
