Author Topic: TSOP in circuit reading tsop test clips  (Read 4868 times)
Offline nandmanTopic starter
« on: April 25, 2015, 12:15:58 am »
Does anyone know if you can read a tsop in circuit?
Many sites say you can not but I see people selling tsop test clips to read tsops in circuit.
just wondering ???
Offline tggzzz
Re: TSOP in circuit reading tsop test clips
« Reply #1 on: April 25, 2015, 09:00:25 am »
just wondering ???
Links?
« Reply #2 on: April 25, 2015, 10:45:28 pm »
just wondering ???
Links?
Well I was looking at the Pomona test clips and the emulation.com test clips
http://www.amazon.com/Pomona-5514-SOIC-Clip-Test/dp/B005T617VQ
https://www.emulation.com/catalog/off-the-shelf_solutions/debugging_accessories/test_clips/tsop_test_clips/
Offline ManateeMafia
« Reply #3 on: April 25, 2015, 10:51:54 pm »
Are you asking if you can read a device like an (e)eprom in-circuit?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: April 25, 2015, 11:56:48 pm »
It depends entirely on the nature of the circuitry in the system it's used in.
You may be lucky and the system might tristate its address bus & control lines when held in reset.
Or you may be able to force enough current to override the address drivers.
Or maybe not.
TSOPS are easy to desolder, so using a normal socket is going to be the most reliable way.
Day Job: Mostly LEDs
« Reply #5 on: April 25, 2015, 11:59:12 pm »
just wondering ???
Links?
What makes you think these have anything to do with programming?
The clue is in the name : test clip
« Reply #6 on: April 26, 2015, 03:35:23 am »
just wondering ???
Links?
How do we locate and use the tristate? I have seen tristate mentioned when using the test clip.  something about connecting tristate to ground.
Offline tggzzz
« Reply #7 on: April 26, 2015, 07:42:18 am »
If you don't understand how the UUT is supposed to work, then having any testclip whatsoever is a waste of time - and may damage the UUT.
Applying inappropriate signals will damage something on the board. If you are lucky it will stop working immediately. If you are unlucky it will survive long just enough to have entered service.
« Reply #8 on: April 26, 2015, 09:01:46 am »
just wondering ???
Links?
Like I said, it will depend entirely on the rest of the system.
