Sure But an bench dmm going down to 1pf with real precision .... i want to see that
6.5 digit doesn't warranty everything you throw at ...
It an useful tool, but very limited in precision ... i never use any capacitance test on every meter i have, one bad mistake and you pooof an input ... way more expensive than using an lcr meter
Unless you use big models / brand
The dmm works with R-C timing, nothing like testing at 100, 120, 1k, 10k, 40k, 100kHz ... or test coils etc ...
If the op wrote very sensitive measurements , it's another game, you have to work in kelvin mode, you want micro volts you have dedicated meters for that, you want micro amps ... same thing
Even a 6.5, 7.5, 8.5 digits meter have its limit, you can't have everything in the same instrument, same for LCR meters, to have an 1 pf resolution, you'll pay a lot ... never saw that resolution under 1K $$$
Not some publicity gimmick loll
