Just some Impressions from the Benning CM11 Clamp Meter.
It feels not as solid and high quality as i hoped, but it is one of only a few meters which can measure mA without disconnecting the circuit. The meter is power by two AAA batteries supposed to last 30 - 100 hours. Depending on usage mode and backlight.
Although it is not the smallest device,
the holster is still a bit too large.
The Measurement leads are average, but i trust them their rating. Overall length is 140cm. AWG 18
I can't comment on the input protection. The only thing i can say that there is some build in.
For the measurements there is nothing to complain, except the slow continuity test.
But the measurement for 0-200mA signals is quite reliable. The value does not drift much and opening/closing the clamp has only a low impact. It seems to use some active technology, because it makes a slight humming sound when in DC ampere mode.
Specs:
DC current range:Measuring range | Resolution | Measurement accuracy | Overload protection |
300.0 mA | 0.1 mA | ± (1.0 % of reading + 10 digits)100 A AC/DC |
0.300 A - 3.000 A | 1 mA | ± (1.0 % of reading + 10 digits)100 A AC/DC |
3.00 A - 10.00 A | 10 mA | ± (3.0 % of reading + 10 digits)100 A AC/DC |
AC current range:
300.0 mA | 0.1 mA | ± (1.0 % of reading + 5 digits)100 A AC/DC |
0.300 A - 3.000 A | 1 mA | ± (1.0 % of reading + 5 digits)100 A AC/DC |
3.00 A - 10.00 A | 10 mA | ± (3.0 % of reading + 5 digits)100 A AC/DC |
DC voltage range (The input resistance is ≥ 2 MΩ.):
60.00 V | 0.01 V | ± (1 % of reading + 2 digits) | 660 V AC/DC |
60.0 V - 600.0 V | 0.1 V | ± (1 % of reading + 2 digits) | 660 V AC/DC |
AC voltage range:
60.00 V | 0.01 V | ± (1.2% of reading + 5 digits) | 660 V AC/DC |
60.0 V - 600.0 V | 0.1 V | ± (1.2 % of reading + 5 digits) | 660 V AC/DC |
Rating: 1000 V CAT III, 600 V CAT IV
