Author Topic: Best 2-ch lab supply in 200 euro range  (Read 1972 times)
Offline mrkva
« on: June 12, 2013, 10:17:59 pm »
Hello,
since my beginners-lab is starting to require some solid power supply, I am looking for some 2ch power supply (I need 2ch because I use a lot of +/- 12V). Any tips?
Shouldn't be above 200 euros (260$).
Thank you!
Offline Paul Price
Re: Best 2-ch lab supply in 200 euro range
« Reply #1 on: June 13, 2013, 02:26:31 am »
Build your own and save a ton of money. There are many topics here about that, some from me, others from others.
Offline uoficowboy
« Reply #2 on: June 13, 2013, 05:58:04 am »
If you don't want to build your own, I'd find a nice used one. $200 is way more than you need for a 2 channel power supply on Ebay. There's a lot of old HP and Power Designs gear on Ebay going for awesome prices. I got a Power Designs TW5005W on there (2x 50V, 0.5A). Definitely my favorite power supply that I own (and I have something of a collection...) I think I paid about $75 and all it needed was a couple capacitors and a little cleaning.
Offline mrkva
« Reply #3 on: June 13, 2013, 06:21:22 am »
Yes, I considered building my own, I even have two home-built ones. But I wanted something with a display, current limiting, etc.. And also, I worked for my friend, and as a reward he offered me he would buy me (new) one.
Thanks for the tips
JuanPC
  • Guest
« Reply #4 on: June 13, 2013, 07:27:01 am »
Instek Totally recomended...
http://www.gwinstek.com/en/product/productbcategory.aspx?pid=38
but in the $200eu range?
Instek SPD-3606 is the best Switching D.C. Power Supply, but is in the $8OOusd. range.
GPS-x303 Series, best toroidal linear DC Power supply,
the gps-4303 is in the <$8OOusd range.
the GPS-2303 is in the <$4OOusd range. fits the bill.
GPC-Series are classic EI transformer design (the only brand with selectable input voltage 110v,120v,220v,240vac), top quality.
you may want to ask yourself, if you want more AMPs,_? More Volts,? or more Displays.?
GPC-1850D = (0~18V/0~5A)x2 + (5V/3A)x1, 3-channels.
GPC-3030D
GPC-6030D
GPC-3060D
GPC-3030DQ
or you can buy singles and link the controls, displays & outputs serial or parallel, thereĀ“s no need to be a 2-ch, unit.
many options available....
EI transformer or switching.
many voltage & amp. ranges,
from the popular GPS, to the super expensive GPR-U.
SPS are switching.
GPS-xx0D are the EI.
« Last Edit: June 13, 2013, 08:15:58 am by JuanPC »
