You are right. The shaft that used to be metal on previous 80 series meters is now plastic. Last year a friend somehow broke the selector dial on his nearly new 87V. I replaced the a broken plastic shaft with a metal one machined from a piece of hex stock (think allen wrench). It was kind of a tricky repair to seat, secure, and center the new shaft into the dial it but turned out well. The meter is in daily use and no problems so far.
