Author Topic: What brand of scope probes are built to last?  (Read 1205 times)
Offline e100Topic starter
« on: June 14, 2018, 01:54:58 pm »
The hook tips on the scope probes that came with my Rigol DS1052E are no longer hook shaped. They are more like an L shape so there's not much stopping them from sliding off. I'm not sure if a mm or so of metal has broken off, or if they have just bent opening up the hook.
Do some brands or designs last longer than others, if so what should I look for?
Online nctnico
Re: What brand of scope probes are built to last?
« Reply #1 on: June 14, 2018, 01:59:52 pm »
The ones from Testec are decent but you have to realise that probes are consumables. None will last forever.
Online Fungus
« Reply #2 on: June 14, 2018, 05:22:47 pm »
How long did they last?
You can get new probes as good as the ones that came with your Rigol for $15. Anything more than that is overkill, really. None will last forever.
Offline Gyro
« Reply #3 on: June 14, 2018, 05:34:00 pm »
It's pretty unusual for them to actually loose any metal, they normally just bend with use. Try gently re-shaping the extended hooks with some fine nosed pliers. It should at least buy you some life extension - best case, complete fix.
Best Regards, Chris
Offline cheeseit
« Reply #4 on: June 14, 2018, 05:45:35 pm »
I've had no problems with my Testec probes and I've seen the Testec hook clip sold separately for peanuts, maybe you can find hook clips for Rigol probes too.
Offline slurry
« Reply #5 on: June 14, 2018, 06:16:01 pm »
It sounds like you are not careful enough and put way too much stress on the hook if it straightens out.
Testec probes are actually really good for the money  :-+
