Author Topic: Best desoldering station on the market?  (Read 22959 times)
Offline ElectronicsNewbieTopic starter
« on: September 09, 2015, 02:54:41 pm »
Hi guys,
I have been using my ZD desoldering iron for a pretty long time. It is just one like below:
You may find it under different brands, models (some with additional: iron tool or hot air tool).
The problem is that I often get tempted to get something better so here we have this thread  >:D
First of all, let's talk about pumps. There are some that use electric pump, and some that need shop air.
What's the difference in performance in real word scenario? I don't have the shop air pump but I may consider it, because it has other useful uses.
To be honest with you, I don't lack that much pressure with ZD, but it's biggest flaw is it's low thermal capacity. I know the mass of the tip is huge compared to the standard soldering iron tip but the heating element isn't very effective at all. To melt some lead free solder joints on a multi layer PCB or on a ground plane I need to rise the temp up. which is always risky. Of course, I could get help myself with soldering iron or some preheater, but on the other hand the ZD desoldering tip itself looks crap compared to the most recent type from Pace.
Does anyone have some hands-on experience on this topic?
Offline fivefish
Re: Best desoldering station on the market?
« Reply #1 on: September 09, 2015, 02:59:44 pm »
I use a Hakko desoldering gun. Very satisfied with it. My only complaint with it is the maintenance needed, otherwise you can clog the nozzle and obstruct it with lead solder or small cut component leads.
Before the Hakko, I bought a cheap chinese desoldering gun (handheld tool similar to what you have). I didn't like it. I threw it away.
« Reply #2 on: September 09, 2015, 03:01:41 pm »
I think this will be something like: Pace ST115 vs Hakko FR400 vs JBC or OKI Metcal.
I would prefer the the larger foot print size unit than a hand held gun.
« Last Edit: September 09, 2015, 03:03:12 pm by ElectronicsNewbie »
Offline helius
« Reply #3 on: September 09, 2015, 03:07:32 pm »
The units that use shop air and a venturi device have higher flow rates and greater vacuum.
Here is a comparison of three Hakko models:
The FR-300 is handheld like the one pictured above; the 472 is a diaphragm air pump bench unit, and the 473 is shop air bench unit.
FR-300472473
Absorption: (lpm)111228
Vacuum: (mm Hg)610600700
Offline KJDS
    • my website holding page
« Reply #4 on: September 09, 2015, 03:09:35 pm »
My favourite three are Pace, followed by Pace followed by Pace.
Every other one that I've used has driven me round the bend.
Offline fivefish
« Reply #5 on: September 09, 2015, 03:11:40 pm »
Too strong vacuum power (coupled with high heat) can lift copper pads and get sucked into the nozzle... (if I'm not careful, it happens with the Hakko 808)
« Reply #6 on: September 09, 2015, 03:16:28 pm »
As I wrote before, I don't lack the sucking power  O0
I wonder if there is a difference in reliability between those two types of pumps?
KJDS, if you know, if you have tried.... how does the Pace handpiece does the job in tight places compared to pistol handpiece?
Offline motocoder
  • Electrical Engineer
« Reply #7 on: September 09, 2015, 03:36:39 pm »
I have the Hakko FR-300 and really like it. I should prefer a bench unit though - a bit of a pain to drag it out every time I need to desolder something.
« Reply #8 on: September 09, 2015, 04:37:18 pm »
I'm not sure but FR-300 doesn't have on-off switch and you would need to pay extra for some kind of stand for it.
Offline motocoder
« Reply #9 on: September 09, 2015, 04:54:37 pm »
It is also true what was said about maintenance on it. You need to remember to clean it before shutting it off, or it will clog. I recently broke off the drill bit that is used to clear the tip. It snapped off inside the tip, and it took me 15 minutes to get it back out. I am not sure, though, if perhaps all these units have similar maintenance requirements.
Offline Deathwish
  • Country: wales
« Reply #10 on: September 09, 2015, 04:56:04 pm »
sell me one
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline dr.diesel
« Reply #11 on: September 09, 2015, 05:01:31 pm »
Not cheap but you asked for the best, I've got a Hakko FM-206 rework station, small and compact, best I've ever used, by far.
A bit loud stock, fan mod required for home lab use.
The following users thanked this post: Fried Chicken
Offline KJDS
« Reply #12 on: September 09, 2015, 05:01:46 pm »
sell me one
I'll have a rummage round and see if I can put together a complete one.
Offline GlowingGhoul
« Reply #13 on: September 09, 2015, 05:06:20 pm »
Get a Pace and you won't feel the need to upgrade any time soon.
Offline Deathwish
  • Country: wales
« Reply #14 on: September 09, 2015, 05:12:53 pm »
sell me one
Offline KJDS
« Reply #15 on: September 09, 2015, 05:31:59 pm »
I'll order some new bits tomorrow, I've got one, but it's more corroded than a 1980's Lancia.
Offline Deathwish
  • Country: wales
« Reply #16 on: September 09, 2015, 05:39:54 pm »
That must be bad then. pm me when you want to talk costs etc ok.
« Reply #17 on: September 09, 2015, 05:51:00 pm »
Have you tried Pace? Please, could you compare your experiences regarding Hakko and Pace?
Thanks
Offline dr.diesel
« Reply #18 on: September 09, 2015, 05:57:10 pm »
Sorry, been using the Hakko too long to give an honest comparison.  But IIRC, the Pace doesn't have quick change heads right, at least not on the DeSolder?
Offline 0xdeadbeef
« Reply #19 on: September 09, 2015, 05:59:40 pm »
I'll just throw in my Metcal/OKi MFR-1350 here:
http://www.okinternational.com/hand-soldering-systems/id-MFR-1350/Desoldering_System_Internal_Pump
Not quite cheap, but also serves as base for a soldering iron.
I used one of these Chinese things before and IMHO, it's no comparison. You can also detach the pistol grip and use it like a (fat) pen. That's actually how I use it.
Only slightly annoying thing is that the membrane pump starts to run for a short period every time you switch the station on - even if you just want to solder something.
Offline mos6502
  • Country: aq
« Reply #20 on: September 09, 2015, 06:11:07 pm »
Don't forget the Denon:
for(;;);
« Reply #21 on: September 09, 2015, 06:17:25 pm »
Hakko desoldering stations, particularly the one's with "quick change heads" have terrible reports regarding failures happening with multiple units.
Here's just one source of reviews indicating a real quality problem with Hakko http://www.amazon.com/Hakko-FR-300-FR300-Desoldering-Tool/dp/B00KWM69C4/
Offline KJDS
« Reply #22 on: September 09, 2015, 06:25:39 pm »
Loosen a grub screw, pull out tip, slide in new one and tighten screw.
Note to self, see if Pace also sell replacement grub screws, otherwise I'll have to have some fun cutting screw threads on my lathe.
Offline mos6502
  • Country: aq
« Reply #23 on: September 09, 2015, 06:28:50 pm »
That seems like a much worse construction than the ZD985.
for(;;);
« Reply #24 on: September 09, 2015, 06:39:12 pm »
I'm not sure about this, because Pace uses this type of attaching with a screw since early 80's...
Do you mind if I ask you where did you get it and how much did you pay for it? Does it have controllable temp. settings?
Any Hakko FR400 users here?
Offline 0xdeadbeef
« Reply #25 on: September 09, 2015, 07:10:48 pm »
Voelkner and Conrad sell it in Germany:
http://www.voelkner.de/products/529596/OKI-by-Metcal-Loet-Entloetstation-analog-110-W-MFR-1350-10-bis-40-C.html
I bought mine from Voelkner via Amazon and for whatever reason, it was quite a bit cheaper this way back then.
Regarding temperature settings: like any other Metcal/OKi product, the desoldering gun of the MFR-1350 uses a "SmartHeat"
HF approach where the temperature is selected via the tip but actually, letting aside very special applications, you will
always use the default temperature tips. I was also skeptical at 1st but actually not having to care about a temperature
setting is a great relief. Indeed every time I needed to set the temperature on my previous soldering equipment, it was
only because it couldn't keep the set temperature when (de-)soldering stuff from/to the ground plane or other cases
where there was a large thermal capacity. With the SmartHeat stuff, you barely notice that something has high thermal
capacity. Stuff like de-/soldering full metal BNC connectors works like a charm without cranking up the temperature to
crazy values.
« Reply #26 on: September 11, 2015, 02:39:58 pm »
crazy values.
Thanks a lot for your input!
Indeed, Metcal looks pretty interesting.
We also have Conrad.pl here but it's a bit more expensive (about 4% more) compared to Conrad.de
So:
Metcal is 687EUR inc. VAT
Pace is 907EUR inc. VAT
Now comsumables:
Pace tips are around 27USD (5-pack) for a standard thermal mass and 60USD for high thermal mass
Pace also has tips to clean the pads that cost 36USD (5-pack)
Pace solder "one cycle life" container costs 14USD (10-pack)
Metcal offers ONLY one tip for 34EUR (both for standard and high thermal mass)
Metcal solder container costs 14 EUR (10-pack)
I think that, when you are replacing in Pace a "one cycle life" container there is no need to replace the small filter within it, where with Metcal you have to add a fresh one.
0xdeadbeef you also have mentioned somewhere about a metal piece that gets smaller, wears out with time?
At first look, the Metcal seemed cheaper then Pace but the tips are way more expensive for Metcal. Replacing a full container seems also to be more expensive...
Offline 0xdeadbeef
« Reply #27 on: September 11, 2015, 03:58:59 pm »
Did I? Can't recall and it's not like anything ever got smaller on my  Metcal/OKi stuff...
Or do you mean the metal wool in the container? If so, see below...
Regarding the containers: I guess you don't want to use them until they are full. However you can use one of them for quite some time if you empty them after each desoldering session.
They are small cartridge barrels with a metal wool pad and a paper filter. Solder gets stuck in the metal wool, but you can take it out and clean it. Actually, you can buy fine
metal wool and put a small ball/pad of it inside the barrel as replacement. So this is IMHO not a real cost factor.
Admittedly, the tips are somewhat expensive. That's a drawback of the SmartHeat stuff. I bought three tips sizes which is good enough for everything I needed up to now.
« Last Edit: September 11, 2015, 05:28:26 pm by 0xdeadbeef »
Offline Fried Chicken
« Reply #28 on: January 08, 2025, 04:59:55 am »
I just got the FM-206;  Which fan did you use/recommend?
Google is spyware
Offline beatman
  • Country: gr
Offline audiotubes
  • Country: cz
« Reply #30 on: January 08, 2025, 06:48:19 am »
I use the FR-301, it has a switch, the Hakko stand cost me 40 euros. The FR-301 does jam occasionally with solder but it's easy to clear. They provide a lot of accessories in the FR-301 kit including a long poker.
Probably the worst thing about the FR-301 is that the nozzles are expensive. I don't remember exactly but I think around 60 euros a piece.
Mine sits next to my Hakko and Pace stations, it takes up less bench space than either one. I'm sure it's not the best desoldering station but it might be the best cost/benefit station.
I have taken apart more gear than many people. But I have put less gear back together than most people. So there is still room for improvement.
Offline Pinkus
« Reply #31 on: January 08, 2025, 10:41:30 am »
https://www.sat-center.gr/en/home/Professional/tools/proskit-ss-331b-digital-desoldering-station.html
Way too expensive - this ZD-8915 can be purchased for less than half the price elsewhere.
However, this ZD-8915 looks similar to the ZD-915 from the first post - just with a more modern housing: weight, suction strength (vacuum) and heat production (Watt) is the same as with the old version. My guess is: there is no substantial difference but one, that disqualifies it in the workshop: the power switch is on the back   :palm:.
I (rarely) use a ZD-915 myself, and I'm generally fine with it - but not totally and not always. Thus I also wonder (like the poster in the first post) whether there are dramatically better tools available. Maybe someone has switched from a ZD-915 to another brand and can contribute to the initial question: how big is the difference?
Remark: perhaps the thread owner 0xdeadbeef has switched to a different system in the meantime and can report on this?
« Last Edit: January 08, 2025, 10:47:21 am by Pinkus »
Offline BillyGo
  • Country: ie
« Reply #32 on: January 08, 2025, 05:47:00 pm »
I think the easiest solution is to stick with the ZD you are currently using but replace the mini vacuum pump with a tank and connect it with external vacuum sources
Offline printplaatreparatie
« Reply #33 on: March 26, 2025, 09:44:04 am »
Found this thread looking for a replacement for our MX-DS1. I'm so done with it. 5 years of clogging and expensive maintenance. I had long drills made for me to help unclog the tips, which helped, but even then I spent hundreds a year on those expensive tips. Handpiece (venturi) needs cleaning as well, which requires serious disassembly. Now that the electrical connector on the back has given the ghost it is finally time to say goodbye to this station. It is okay for hobby, but not suitable for daily work.
Is the Pace ST115 really that much better? I'm a bit on the fence about the internal pump. I do like the instantaneous vacuum that the shop air creates with the venturi but I don't like the noise of the air compressor.
Let me know if you are interested in a a free MX-DS1 handpiece. I have 2 pcs, as well as one stand, two working tips and the specially made drills to unclog those tips.
« Reply #34 on: March 28, 2025, 03:04:19 am »
I am very happy with my Hakko (I have the FM-206 with the associated handpiece).
I believe there's an older Hakko that can be had used (with parts still available) that's similarly fantastic.  Vacuum desolder  is a finnicky and not-straightforward affair, so it's worth going with a company that has the experience, knowhow, and ability to implement attention to detail.
Google is spyware
The following users thanked this post: printplaatreparatie
Offline helius
« Reply #35 on: March 29, 2025, 06:19:31 pm »
The Pace stations do something clever, which I think they patented: the pump is 12 VDC, but they pulse 24 V into it so that absorption is fast. The Hakko FR-301 is also fast because the pump is close to the working end.
Clogging is a matter of solder freezing in the handpiece before it reaches the collection tube. You can reduce clogging by leaving the pump running long enough to clear it each time: 2 seconds is the recommended time. There are a lot of different designs to try to reduce clogging by changing how fast liquid solder moves through the tip; Pace's nozzles for the SX-70, SX-80, and SX-90 are all different, because they lengthened and narrowed the "tail" of the tip to try to accelerate solder into the trap.
I wonder if you could just shoot some "carb cleaner" into the venturi?
