Dam, the quoting system has gone down again, so I'll have to cut and copy and hope that you all can catch my drift.
Quote from: Tomorokoshi on Yesterday at 02:42:55 pm
2. Let's say the cost of a Fluke is $1000, and the cost of an alternative is $100. It only takes one failure event to lose this savings.
You might want to expand on your math. If one casts $1000 and the other cost $100, then the cheaper one only needs to last 1/10 the time before the saving are lost. Do you have another consideration you are factoring in that we don't know about?
Quote from: jonpaul on Yesterday at 03:05:16 pm
US Kline
Do Kline actually make any of their meters?
To the OP: Brymen's top level meters generally meet all the same specs as Fluke and are also independently certified by the same people (UL) to meet those specs. I would suggest getting a couple and trying them out. See for yourself how they stand up.
We can consider the total costs of a failure in the field. Feel free to propose other numbers.
1. Starting with the savings: $900
2. The cost of one replacement: $100
3. The cost of getting a replacement ordered. An hour or two of office time: $100
4. The opportunity cost of waiting for the replacement to arrive. A couple days of lower-priority work: $500
5. The opportunity cost of having the technician without the tool at the customer. A few hours of field time: $500
6. The downtime cost at the customer if the technician can't get work done: $500 (Depends greatly on the situation. Could be multiples of this amount.)
7. The cost of reputation, etc.: ?
The point being that the line-item cost difference is easily noticed and accounted for, while difficult to identify costs don't enter into the accounting. For instance, is it trivially easy to purchase the new meter, or does a purchase requisition have to get filled out, get approval, go to Purchasing, wait for delivery, etc. That differential is difficult to measure, but it shows up as an indistinct "tax" or drag on efficiency and productivity.
Surely then it makes perfect sense with the high costs attached to meter failure and the lower purchase price of the excellent Brymen 867/869 meters that you could comfortably afford to order in a few extra meters to allow for such unlikely events? That way, if and when you do happen to get a failure, issue another one from stock and start the process of ordering a replacement so that will always have a small float of meters to hand for emergency use and still be way under the cost of getting new Fluke meters. I have both Flukes and Brymen meters but only the Brymen has the CAT IV, 1,000V rating, and that is the meter I use for almost all of my measurements, it also has dual display and the barograph and can be retrofitted with data logging feature for those that really need it.
