Hello gang!
I don't understand how you all manage to land probes properly in your circuit boards and keep them there. Probing stuff is always a nightmare for me, especially higher speed stuff (the DIP1400 probe from niko is nice but how do you
actually use it? I'm not smart enough to figure that out).
So after weighting my options last night I arrived to the conclusion that maybe building my own probe isn't as crazy as it sounds. Of course, if you want to do it and then sell it to me, all the better.
There are two design targets:
1)
Active probe that can in some capacity reach the whereabouts of 1 GHz. We don't need absolute flatness, just something that works.
2)
PCBite form factor. This is mandatory. If you want to build a generic probe, please do, but this thread, however short it is going to be, will be about a PCBite form factor. For the uninitiated, this requires the probe to have a mechanical termination (M4 I believe) soldered on:
I would like a probe that's actually usable, one that I can position easily and won't bother me much. There is a new series of oscilloscopes coming to market, and we will need matching probes to take advantage of them!
I think this is a day's worth of work for the design, is anyone interested in reviewing my schematics once they are done? Basically I think that I just need to add a 5x divider in front of the
reference design that has already been tested by another member.
- I think I should use multi-cb's defined stackup, 4 layers
- 0201 components are a must for the small form factor
- Pogo pin on the probe tip, but I'm unsure on how to handle the ground connection.
- Should power supply be external?
- Should power supply (the cable) be shielded? I'm sure I'll add some onboard filtering, maybe a tiny LDO? Idk.
- What about the ground clip, what's a good target, 5cm or less? We need to find tiny clips grabber or the clips are going to be longer than the ground wire itself!
Any input welcome, I don't want to build this, but I truly believe it's the best option that I have.
