Author Topic: Best portable 4ch scope  (Read 1991 times)
Online Fungus
Re: Best portable 4ch scope
« Reply #25 on: October 12, 2020, 06:12:19 am »
Any chance you can plug in a USB stick and grab screenshots? That's mighty useful and I don't want to have to connect up a laptop via USB or Ethernet just to capture screenshots. It says you use a mouse so I presume it has at least one USB port.
The micsig is an Android tablet, it runs Android apps (the oscilloscope is just a built-in app!)
This video is quite informative:
For "four channel portable 'scope" I don't think you do better than that.
(hell, I'm not even sure you can do much better in a desktop 'scope in that price range...)
« Last Edit: October 12, 2020, 06:48:54 am by Fungus »
Online 2N3055
  • Country: hr
« Reply #26 on: October 12, 2020, 06:41:24 am »
1. E Plus has more acquisition memory.  C has 28MS total, E plus has 70 MS total. To me not worth doubling the price. All else is same AFAIK.
Then I agree. Not worth the price just for extra memory and waveform acq speed. Thanks for the confirmation.
2. Best view angle is at right angle or slightly above.  It has stand in the back that puts it at proper angle when on desk.
If the stand has it "leaning back" from straight up and down, then they presume your head will be above the scope, correct? Hence the comments about being "tall enough". I think I understand. The poor visibility would occur if your line of sight is below perpendicular of the screen. Do I have that correct?
3. It feels sturdy and good quality. Encoders are nice and firm. It has no major problems, but it's basic scope. It has no AC RMS measurement. It has no measurement statistics. You have table mode for decodes but only full screen. So it's ether graphic mode with waveform or table mode. You can't switch between graphic and table decoding without loosing data. There is no segmented memory. CAN is only basic CAN, there is no CAN FD.
That's OK, not buying it for protocol decode (have other solutions for that when necessary).
All in all, what i has works very well, it is good quality, battery runs for 5+ hours and is well worth the money for what it is. Question is : is it enough of the scope for you?
Sounds like it will do the job! I need a digital storage scope with four channels that can display analog waveforms to a few 10's of MHz. Traditional triggering is adequate. The ability to capture four signals and then zoom in/out and back/forth pretty much covers it. And it runs on a battery for 50%+ of a working day. If it's rugged enough to last a while - and it sounds like you think so - then we have a winner.
Hello!
just a quick recap
1.  :-+
2. Something like that. Mind you, it doesn't get invisible if you are below center line, but contrast starts washing out quickly. If it is on a shelf above you it's not that good. On a desk it's great pretty much anywhere. Word of warning, I'm 6'5"... :-DD
3. Protocol decodes do come with scope (check with dealer, in EU they all come free) and they work OK. In table mode you can interleave 2 decodes so you can see them in coherent time...
4. USB ? Sure it can. You also have internal 8 GB and can save REF traces, captures, screenshots and videos... Yes MP4 of something going on on the screen. It also has Ethernet and WiFi, and you can install internal FTP server so you can grab stuff from the PC directly...
Some other comments... It has very nice implementation of color grading, boots quite fast, BNCs are on the top (I was afraid they would get in a way but it's fine), you have a over the hand handle on left side to hold it safely, it has HDMI out (it looks great on 42" TV). Charger is powerful and seems good quality mechanically, but it's electrically noisy. A replacement medical grade PSU is recommended if you want to work plugged in. Battery is user changeable and available as spare part.
All in all, very handy little thing that seems to work just fine for a "grab and go" situations.. I have for half a year and it already paid itself off in just few interventions, where we could diagnose problem on the spot and just replace failed modules, instead of unmounting whole device and haul it back to office for diagnostics...
Regards,
SiniĊĦa
The following users thanked this post: fkfaraz
Offline DaneLaw
« Reply #27 on: November 27, 2020, 02:40:16 am »
 their screen is too dim and has a very bad viewing angle.
Dim?, I'm getting above 400nits (414) when I check the brightness.. often need to turn it down indoors to 0-25%.
The biggest problem I have with the screen is the massive glare that can be a con, but they include an antiglare screen protector so one can take that approach.
But I do feel the latest OTA updates have made the touch- more inconsistent.
Here a slide with pictures of the screen and also the delay when on wireless.. Its around 0.200ms to 0.250ms in my test.
for 400bucks (1104C) with battery incl tax shipping etc I feel it's a steal, though +30USD for the Micsig bag..(love the mobility in lack of a bench)
But IM a noob with minor perspective and just trying to learn as I go, as a newcomer to DSOs but + for high res OLED panels in scopes (sooner the better  >:D )... that inky black looks wicked, and response rates are usually impressive on OLED panels, though perm retention, could be a hassle for scopes with static, though they don't need to run them as hard as we see on TVs or Mobiles/tablets, so could work,
Here beside a Samsung Tabs5e 1600P OLED
Video on the wireless feature from the scope to an Android tablet running the Micsig app. (works the same on Ipad or on PC) just a crude interface like you have on the scope itself. (any good third-party programs that can talk to these scopes?)
https://i.imgur.com/9K0mJxu.mp4
I think the screen is great for a scope in this price ballpark, as it ain't like the norm is much higher, Im left with the impression you need pursue fx models from R&S that from videos looks to have a gorgeous big screen (though reflective).
Here's a"direct-on" shot and one from the side.
I recall this is the lowest brightness.
and this is highest, I recall but some time since so not 100% sure and most of these pictures are dimmed down to not mess the cam-exposure.
and hmm, no problem to read EEVblog forum on the scope for information about scopes. :palm:.
A slideshow with many pictures of the Micsig screen
https://imgur.com/a/bZKztlL
Congrats with the Fluke, way out of my budget.
« Last Edit: November 27, 2020, 04:24:42 pm by DaneLaw »
Online blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #28 on: November 27, 2020, 03:06:01 am »
I found out with some ferrite filter magics and some careful probe layout, the built-in inter-channel isolation allows me to reliably measure high side gate signals on even GaN/SiC power electronics, and this feature alone, if from Tektronix, would be in north of $40k (4*$9k probes and a $5k scope with TekVPI interface).
20dB less CMRR for 20dB less money, not a bad deal for me.
Offline DaneLaw
« Reply #29 on: November 27, 2020, 03:43:56 am »
Certainly don't sound like it, though "cost" is relative when it comes to pro-lab-gear.
as noted Im new to scopes, so more trying to make sense of it all, with a cheap 70USD FY6900/60mhz but sofar been impressed with the Micsig 1104C when you have the price in mind.
Basic
Do like the mouse-support and you can plug scopevalues on the fly to datasheets on the units itself.
Though would have prefered that Micsig locked the 256intensity-grading feature to a specific knob (fx the top X or Y knob) perhaps with the shift button, as that grading-feature is vital, also appreciated the color-intensity grading aspect, and way more then I expected I would.
and I love that I have power in spades' with these 90watt capable adjustable DC + Powerdelivery + Qualcomm-QC powerbanks with 8x LG HG2 3000MAH in each..
And makes it very easy to just take a TypeC 12v PD-decoy-cable to DC. if you need more power away from home.. it only uses like 25watt
and the included AC to DC-charger (5A), is a spiky noisy fellow
- a plus with these low noise high current-powerbanks, and the 1104C also works fine with these cheap 35USD Hantek current clamps and quite accurate when you have it in current mode and amp values...
« Last Edit: November 27, 2020, 04:30:44 pm by DaneLaw »
Online Fungus
« Reply #30 on: November 27, 2020, 07:47:14 am »
I'm with you. I've had mine for a couple of weeks and there's no problem with brightness, only reflectivity.
The supplied screen protector completely fixes the reflectivity. They should install them at the factory.
