Author Topic: Kyoritsu 1021R multimeter  (Read 510 times)
Offline vutt
  • Country: ee
« on: June 13, 2020, 11:24:50 am »
Hi!
Long time EEVblog YT channel watcher, first time forum poster here.
I have been using a long time Kyoritsu model 1009 entry level multimeter. It is still working just fine. It is just a little bit slow side. Recently I felt need for secondary general purpose multimeter. Since this brand served me well I went down with not so cost effective route and bought new one from same brand.
So I ended up with 1021R model.
[attach=3]
Positives:
  • A lot faster than 1009
  • Bigger, back lit screen, although with less contrast than 1009
  • A lot nicer probes, doesnt miss a beat with continuity test
  • Current measuring is simpler to use one 10A terminal, it also allows me for upgrade path - it supports external clamp sensors
  • TrueRMS
  • Measuring precision is also slightly higher compared to 1009
So what about safety (this is one of the reasons I'm leaning towards bigger brands in sub 100€ price range)
It is rated CAT IV 300V / CAT III 600V / CAT II 1000V - not that relevant to my use cases, but it's nice to have capability for rare cases I might need it
Fuse is nicely contained in separate compartment with correct values in line with rating
[attach=1]
PCB pic:
[attach=2]
Q: Could you educate me. What's that clear glass component with "202 T08M" markings next to two green bulky MOV-s (or PTC-s)?
All in all I'm happy with purchase. Since I didn't find previous discussions about this model here decided to share some pics here.
« Last Edit: June 13, 2020, 01:01:55 pm by vutt »
Online AVGresponding
Re: Kyoritsu 1021R multimeter
« Reply #1 on: June 13, 2020, 11:29:18 am »
Loving the neon used as a GDT, almost makes you wish for a view port so you can watch as you deliberately overload it!   ^-^
Addiction count: AVO-BlackStar-Brymen-Fluke-Hameg-HP-Keithley-IsoTech-Mastech-Megger-Micronta-Solartron-Tektronix-Thurlby-Time Electronics-TTi-UniT
Online fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #2 on: June 13, 2020, 01:14:54 pm »
« Last Edit: June 13, 2020, 01:19:53 pm by fanOfeeDIY »
Offline vutt
  • Country: ee
« Reply #3 on: June 13, 2020, 02:49:18 pm »
Thanks fanOfeeDIY for link!
If it's GDT then those green ones are most likely PTC-s.
Online fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #4 on: June 13, 2020, 03:51:52 pm »
The green ones are definitely PTCs, somehow they are mostly written as polyswitch or resettable fuse, and rare to see PTC here written in Japan
« Last Edit: June 13, 2020, 04:47:36 pm by fanOfeeDIY »
Offline sleepymaker
  • Country: id
« Reply #5 on: November 27, 2020, 09:31:56 am »
How about the features and ranges?
Is it able to measure milliamps and microamps?
