Author Topic: Best sub-£50 meter with really good continuity  (Read 1076 times)
Offline cybergibbons
« on: December 04, 2017, 12:04:45 pm »
I'm looking for a meter that is available in the UK without having to wait weeks for a Chinese shipment, as I am recommending it for others to buy.
It's for hardware reverse engineering, so by far the biggest requirement is a good continuity buzzer, and ideally comes with decent probes.
Any recommendations?
Offline tautech
Re: Best sub-£50 meter with really good continuity
« Reply #1 on: December 04, 2017, 11:14:08 pm »
For continuity, check out data that Joe has put together on meters.
He found one sooooo fast it could play Van Halen while in continuity mode.  :-DD
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/
Avid Rabid Hobbyist
Online rhb
« Reply #2 on: December 04, 2017, 11:22:00 pm »
Mount a DPDT  slide switch on the side of the case and add a small piezo sounder.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: December 05, 2017, 02:31:02 am »
The UT136 Family is very well built, compact and has a lightning continuity tester. I have a UT136C (with temperature) bought for US$19.00.
Actually, 14 pounds at Amazon:
https://www.amazon.co.uk/UT136C-Handheld-Auto-ranging-Digital-Multimeter/dp/B06WGRB1VV
Offline joeqsmith
« Reply #4 on: December 05, 2017, 02:58:24 am »
How loud do you want it, how fast, latching....  Really depends on what you personally like.  This is why when I test them, I don't just touch the leads together and call it a day.  I want to know the thresholds, open circuit voltages, short circuit currents.
:-DD
https://youtu.be/svJXiMMZzcQ
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Online Fungus
« Reply #5 on: December 05, 2017, 06:49:42 am »
Yes, but the reason it can do that is because it's non-latching (and sounds nasty when you use it). Still, at this price range and in a hurry you're unlikely to get better.
I always felt like a buzzing multimeter is the wrong way to do continuity. I'd like a LED on the probe that's in my hand. Maybe something could be built with an Arduino.
« Last Edit: December 05, 2017, 06:52:57 am by Fungus »
Offline kalel
« Reply #6 on: December 05, 2017, 06:59:07 am »
That's a good idea, but depending on implementation, it might still be easier to hear the sound than focus on the light.
Online Fungus
« Reply #7 on: December 05, 2017, 07:03:55 am »
If you're not looking where the probe is then what use is a buzzer?
