I find the N2863B probes very awkward to attach and remove. The scopes BNC jacks are a bit too recessed and due to the odd rectangular shaped neck of the probe connector, when I remove a probe, my fat fingers push against the adjacent probe and more of a concern I find I am pushing
against the small delicate vertcal control knob.
I understand the basics of matching probe impedance to the scope but find the Agilent recommendations a little confusing so I appreciate any advice.
The MSOX2024A has a 1Meg ~11pF input. The 10:1 N2863B is listed in the Agilent literature as a having 10Meg input resistance (when terminated into 1Meg input. The probe connector has 10Meg//15pF printed on it.
Prior to buying the MSOX2024a, I picked up four new Agilent 10073D (500Mhz) 10:1 probes for the InfiniiVision 5000-6000 series at a hamfest for a great price. These are constructed much better than the N2863B, having narrow rounded probe connectors that make attachment and removal from my MSOX2024a a breeze. The InfiniiVision scopes also have 1 Meg input at 12pF and recommended probes are the N2863B or 10073D BUT the 10073D has a input resistance of 2.2 Meg even though it is 10:1.
My basic understanding is that at lower frequencies the 10:1 attenuation is driven by the scope's 1 Meg resistance input and probes input resistance to give a resistive 10:1 voltage divider while at higher frequencies it is mainly driven by capactive voltage dividing.
How would the 10073D probes underperform the N2863B probes?
I did a fast test this by comparing the two probes in Ch1 and Ch3 with a constant RF voltage source (HP8920A at 0 dBm) stepping from 1khz to 300 Mhz and I compared the Vpp measured by the MSOX2024a. Both probes behaved nearly identically except the 10073D was reading about 5% lower between 160 - 200Mhz compared to the N2863B. However, between 200Mhz and 300 Mhz the attentuation of the signal was much steeper for the N2863B, I was surprised that for a 200Mhz scope, with the 10073D probe the sensitivity and measured rise time of the 300Mhz RF signal still looked pretty good with the 10073D. Next I compared a 50Mhz square wave with both probe types and saw no difference in shape, rise time of Vpp.
So I guess I am good to go with the 10073D?
j
