After some further testing
I see that I can't switch to CH2, although it indicated that it does that.
Commands that give a response
$E3434* PRECISION MODE ON EOK
$E3535* PRECSION MODE OFF EOK
$E2020* SEL TEST MODE EOK
$E2222* SEL CH2 FREQ EOK
stays on CH1 !!, EDIT power cycle needed $E2121* SEL CH1 FREQ EOK
$E3030* SEL CH1 50R EOK
$E3131* SEL CH1 1MR EOK
$E3636* LPF ON EOK
$E3737* LPF OFF EOK
$G* GATE TIME 0000000100 mS GOK
never changes$R* RST ROK
$B00960* CHANGE BAUDRATE TO 0000009600 BPS BOK
$B05760* CHANGE BAUDRATE TO 0000057600 BPS BOK
$B11520*
reading failed, although it did change it$D* $BPIR ,00024000000.13566796,+00093,DOK
power reading CH2$D* $APIR ,0009999999.999803921,+00128,DOK
Ref-out to CH1 50Ω 12.8 dBm $D* $A I ,0019649419.668446932,-00414,DOK
Ref-out to CH1 1MΩ$D* $A IR ,0000000000.000000000,-00536,DOK
CH1 50Ω no signal$H* SET MASK_H FREQ 0000005536 MHz HOK
after calibration with GPSDO (everything with 0.1s gate time since I can't change it)
Calibrated the USB reading, not output ref. since the loop had an offset of 1.1mHz on 10MHz
Count 1014
Average 10000000.00050616968934911243
Peak Peak 0.007041184
Count 292 (later)
Average 9999999.999578076633561643836
Peak Peak 0.006613712
Count 1258
Average 100000.0014598554332273449921
Peak Peak 0.001500004
Count 285
Average 999.9999378147719298245614035
Peak Peak 0.000099010
only two possible numbers, see below (A stands for Channel A=CH1 and B is for CH2)
$A0000001000.000000000,
$A0000000999.999900990,
Count 219
Average 9.999999771689497716894977169
Peak Peak 5.00E-7
$A0000000009.999999500,
$A0000000010.000000000,
Looks like I will need to send it back if I don't find a way to go to CH2 and change gate time....
FA-5 is not working despite the recent 2024-06 date.
edit Timelab files attached, keep in mind the GPSDO is less stable below 10sec hence the drop.
Sending the channel change command (to CH2) and then power cycle seems to work to get CH2
Count 1201 (1GHz on CH2)
Average 1000000001.117715858817651957
Peak Peak 1.27398220
Count 1785 (100MHz on CH2)
Average 100000000.5087346761008403361
Peak Peak 0.29005594
