Hi Electro Fan,
the topic of timing, accuracy and stability is a much wider and deeper field, as it looks from the ouside (the rabbithole of time nuttery).
And I am in no means an expert in this.
If you feed the couter input with its 10 MHz outut, you see the "hard limit" of the counter. Your results can never be better and it does not mean, that your results can be as good.
If you feed the counter with a signal form a generator and both are synced to the same soure, imho there is not much to gain from that.
If you want to evaluate an oscillater, you need another one which is at least a magnitude better.
The BG7TBL GPSDOs are rumored to have an inherent error in the range of about 2 mHz. It is not clear to me which models are affected.
I have a BG7TBL and a Samsung gpsdo and I have found this to be the case for my unit, but I have not done extended tests.
I suggest to check out the tinyPFA Phase Frequency Analyzer:
https://www.tinydevices.org/wiki/pmwiki.php?n=TinyPFA.HomepageI got a used NanoVNA-H4, which can be flashed with the TinyPFA firmware.
I found this to be a very interesting low cost device to experiment with GPSDO, OCXO and counters.
The FA-2/FA-3 and the TinyPFA do work with the Timelab software.
This can keep you busy for quite some time
Regards
Chris
