Author Topic: BK2120 Oscilloscope owners what is this possible issue?  (Read 2291 times)
Offline Dark PrognosisTopic starter
« on: October 19, 2013, 12:05:59 am »
Scope works perfectly fine but every so often it makes a loud popping sound on the right hand side as if a relay were kicking in.  What in the world could this sound be?  When the sound happens there is just the sound as the trace stays steady on the screen.
Re: BK2120 Oscilloscope owners what is this possible issue?
« Reply #1 on: October 19, 2013, 03:08:34 am »
When I turn it off it will make that noise as it cools down so it must be a mechanical heat issue which is a tad worrisome.
Offline Stonent
« Reply #2 on: October 19, 2013, 03:20:05 am »
I had an old Mitsubishi Diamondtron monitor that started doing that, when it happened the screen would go real fuzzy for about 1/2 second and go back.
I eventually just got rid of the monitor. But it was a problem inside it.
Offline Kryoclasm
  • KL3DL
« Reply #3 on: October 19, 2013, 03:22:48 am »
You might have some screws loose! Well the scope too.   :D
I'd pop it open and make sure everything is secure, just make sure it isn't powered up or plugged in. Look for thermal scorch marks too.
“I predict that very shortly the old-fashioned incandescent lamp, having a filament heated to brightness by the passage of electric current through it, will entirely disappear.” -Nikola Tesla
« Reply #4 on: October 21, 2013, 01:48:38 am »
Yeah, it does it even when off as it is cooling down.
« Reply #5 on: October 21, 2013, 02:55:22 am »
Well, I just spent the last 45 mins with it open and every single last screw needed from half a turn to 2 or 3 turns.  I also saw a 7812 that I couldn't get to without a lot of removal of parts but it had a different screw attaching it to the heatsink AND the screw was plastic.  Obviously this was changed at some point but with the thin layer of dust all over the parts and board it was not recently.
There was a power transistor on both sides of the back and the left one had a thermal pad but the right side one had none so I added thermal grease just in case.
If it continues to make the thermal pop it will just have to break to figure out what to replace.
