Author Topic: Inside the Krautkramer Ultrasonic Flaw Detector USE 1  (Read 458 times)
Offline Camilo71515Topic starter
  • Country: ar
« on: August 28, 2021, 10:52:01 pm »
Hi there! I've finally got my hands on to the Krautkramer machine and decided to share some pictures of this beautiful aparatus with you.
Inside of it I could find quite a variety of components, Si and Ge transistors, metal can opamps and DIP IC's, a Nuvistor and some Vaccum tubes.
All the modules seem to be in perfect condition with the exception of some jammed potetiometers. I don't know if this works, nor do I have the probe to test it. Sadly I can't repair it since I don't have a need for it nor have the time it may need, so I may use the modular structure to build something else
The following users thanked this post: ace1903, shakalnokturn, factory, D Straney
