Author Topic: BNC Male to Dual Banana Female & BNC 50ohm termination  (Read 1774 times)
Offline 2XTopic starter
  • Country: gr
« on: August 07, 2017, 07:17:05 pm »
does anyone know where I can find a good quality of these two connectors which use the Dave to reduse the noise at 14:40 and also the other two 50 Ohm plugs at 24:09.
I find the below connectors from china but I don't know if they are good quality and it is worth to buy them.
BNC Male to Dual Banana Female Jack Coaxial Cable RF Binding Post Adapter 2pcs
http://www.ebay.co.uk/itm/BNC-Male-to-Dual-Banana-Female-Jack-Coaxial-Cable-RF-Binding-Post-Adapter-2pcs-/361397064687?
8Pcs BNC Female Jack to RCA Male F/M RF Coaxial Cable Adapter Connectors
http://www.ebay.co.uk/itm/8Pcs-BNC-Female-Jack-to-RCA-Male-F-M-RF-Coaxial-Cable-Adapter-Connectors/192141060221?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140122125356%26meid%3D45a974f8ff41431ba324dd590840716a%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D361397064687
14:40
https://youtu.be/Edel3eduRj4?t=880
24:09
https://youtu.be/Edel3eduRj4?t=1449?
Offline alm
Re: BNC Male to Dual Banana Female & BNC 50ohm termination
« Reply #1 on: August 07, 2017, 07:30:28 pm »
For good quality, see Pomona:
Female BNC to double banana plug
50 Ohm BNC feed-through terminator
The BNC male to dual female banana jack adapter you post is the opposite of the first. And a BNC female to RCA is something you might use to connect a scope to an analog audio device, not to measure a power supply. I personally would not worry about the quality of cheap BNC to banana jack or plug adapters, it is not like these are for high frequency use anyhow.
For a much cheaper feed-through terminator that seemed to perform decently (but note that they may have changed construction):
https://www.eevblog.com/forum/testgear/banggood-50-ohm-bnc-feed-through-terminator-a-quick-review/
The last thing Dave shows is a probe tip to BNC adapter. These often come with good probes. Some probe manufacturers (e.g. Keysight, Tektronix, Lecroy, PMK, Pomona, Probemaster) may also offer them for sale as optional accessory. If they do not, then you may have to find another one from a probe that has the same dimensions. These dimensions are not standard, so double check them.
The following users thanked this post: 2X
  • Country: gr
« Reply #2 on: August 07, 2017, 08:17:20 pm »
Hi and thanks for the reply,
For a "probe tip to BNC adapter" I find the below on Digi-key from LeCroy.
Digi-Key Part Number: PP005-BNC-ND
Manufacture: Teledyne LeCroy
Manufacturer Part Number: PP005-BNC
Description: PROBE TIP-BNC ADAP
https://www.digikey.com/product-detail/en/teledyne-lecroy/PP005-BNC/PP005-BNC-ND/3587091
Offline alm
« Reply #3 on: August 07, 2017, 08:25:47 pm »
Should work fine if you have a matching LeCroy probe. If not, then only if your probe happens to have the same dimensions as the LeCroy (PMK?) probes. Like I wrote, these are not generic parts.
  • Country: gr
« Reply #4 on: August 07, 2017, 08:35:18 pm »
I have the probes from the oscilloscope "RIGOL DS1102E". Does anyone use a "probe tip to BNC adapter" like this from LeCroy in RIGOL probes?
