Author Topic: Picoscope at tequipment...  (Read 2371 times)
Offline alank2Topic starter
« on: August 05, 2017, 12:55:12 am »
They sent me their clearance ad this morning - if anyone is looking for a 2 channel picoscope, they marked down a single 2207B 27%.  I put it in my cart to test if it would let me also do the eevblog discount and it took another 6% off bringing the price down to 340 something.  I've got this model and it tests quite a bit better than its 70 MHz rating and it is the least expensive model with the 1 GSa/s sample rate.  It is a good deal for anyone looking for one of these; they are not often discounted much.
http://www.tequipment.net/Pico/2207B/PC-Based-Oscilloscopes/?v=0
Offline ralphrmartin
    • Me
Re: Picoscope at tequipment...
« Reply #1 on: August 05, 2017, 05:12:38 pm »
Picoscope quite often have scopes for auction at reduced prices on eBay.
« Reply #2 on: August 05, 2017, 05:33:18 pm »
Only on their older models...
    • Me
« Reply #3 on: August 06, 2017, 04:44:24 pm »
Which also run the latest software. I got a 200MHz model for £300, with admittedly a low sample rate.
Online JPortici
« Reply #4 on: August 06, 2017, 05:16:30 pm »
and almost no sample memory
« Reply #5 on: August 06, 2017, 05:25:11 pm »
Yes, that is something cool about Pico's for sure!
The best ones in the 2000 series have a good balance of sample rate, deep memory, and bandwidth)
Some stand out to me as being the best value:
2206B - the cheapest 2 channel that gives decent performance (50 MHz, 32M memory, 500MSa/s, 2 channels).
2207B - the one I mentioned above that there is ONE ON SALE - (70 MHz, 64M memory, 1GSa/s, 2 channels).  I've got this model and its bandwidth much better than 70MHz.
2406B - the cheapest 4 channel that gives decent performance (50 MHz, 32M memory, 1GSa/s, 4 channels)
Note that the 2406B is given the faster 1 GSa/s sample rate even though the two channel model is only 500 MSa/s.
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #6 on: August 06, 2017, 05:49:57 pm »
But with ETS. What software allows? 20GSa/s?
Also can use it as MSO with external DAC.
    • Me
« Reply #7 on: August 07, 2017, 06:37:50 pm »
The one I got was a 3206 MSO with 128MSamples
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #8 on: August 07, 2017, 09:01:16 pm »
Good score, then you got it all covered w/o trickery :-+
