Author Topic: A look at the Uni-T UT210E  (Read 505666 times)
Offline kkontak
  • Country: gr
Re: A look at the Uni-T UT210E
« Reply #875 on: November 08, 2023, 12:36:23 pm »
Just found out this hack and tried on my UT210E. Worked great!
Two observations:
1. By adding a 2nd feature (AC mV) in NCV mode, using the below 2-byte hack, you also add a 3rd feature (AC A 6000A) which seems silly to me. The $1D byte is really useful for the mV feature to work? Because all it does, is to enable the 3rd feature.
NCV, NCV mV
9C: 00 02
AC: 00 1D
2. When I opened my unit, I noticed a QC fail. The R37 resistor was soldered only in one of the pads. Still worked tho, even after years of beatings around in the toolbag on many work fieldtrips.
« Last Edit: November 08, 2023, 12:53:25 pm by kkontak »
Offline ceut
« Reply #876 on: April 27, 2024, 11:14:03 pm »
Time has passed since my contribution here...2017   ::)
A quick follow up of a problem of one of my 2 UT210E (the one I have given to my brother).
I have to fix his FAAC D600 motherboard (from a motor garage door) which has failed and some burned part on it.
So, after having fixed it at home, I have gone to his home, and when I have rechecked the power voltage line, his UT210E reads 51V DC  :o  (for a 24AC 86VA transfomer, which I have checked at home at 24.85V RMS on my Keysight U1233A and with my Siglent DSO 68V peak-peak (34V max and -34V min)).
=>So big fail for this 6 years UT210e old that I have flashed and contributed for mod it here  :-+ https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg1316832/#msg1316832
I have worked on it for about 3 hours, reflashing other 24C02 calibration file, checking many parts etc..
All other functions worked well.
Then I have removed fully the motherboard, and found the issue  :o
==> Wear of the rotary switch !  :palm:  :palm:
2 traces have lost their solder mask  as you will see on the photos.
I have put a piece af tape, and it is working again, with the good calibration I have made 6 years ago  :-+
Now I have to find how I can isolate this traces... will try some UV solder mask
« Last Edit: April 27, 2024, 11:18:24 pm by ceut »
The following users thanked this post: multiJ, Kean, RoGeorge, ledtester, Mortymore
Offline kloetpatra
« Reply #877 on: May 02, 2024, 10:04:06 am »
I mainly use mine in 2A mode (once a week). A while ago I noticed incorrect Amp readings or mode changes (beep) without touching. Firmly pressing the selector wheel the issue goes away. So I think it's a bad contact in my case.
Just checked the inside and I can see there's way much more grease. Maybe you should add some grease too?
While the traces still show no signs of wear there's a little bit of green residue on one of the copper spring contacts.
« Last Edit: May 02, 2024, 03:59:59 pm by kloetpatra »
Offline ceut
« Reply #878 on: May 06, 2024, 05:48:29 pm »
wow  :o
This grease was put originally from factory ? Is it a recent batch ?
On my 2 UT210e from 2017: no grease at all inside.
I have fixed the 2 mine which were having the exactly same wear problem on the same place/traces.
=>Fixed with UV solder mask, then a very little WD40 on the rotary switch+trace - hope it will last with that.
Offline kloetpatra
« Reply #879 on: May 06, 2024, 07:20:51 pm »
Yes, I didn't add anything. I think it's from 2015. Nice fix, I hope it'll last long. I'd rather recommend silicone based grease. WD40 technically is not a lubricant. Moreover it is hydrocarbon based. Amorphous plastics and hydrocarbons don’t play well together. Hydrocarbons attack the chemical structure of amorphous plastics and break them down. It would be safe for crystalline plastics.
amorphous: PC, Styrene (including ABS), PVC
crystalline: PP, PET, PE (all types), Nylon
The following users thanked this post: Mortymore
Offline cybermaus
« Reply #880 on: September 24, 2024, 06:11:09 pm »
Apologies if this was mentioned before in this very long post.
I have a UT210E, and it has a DM1106EN chip
But I have had it for a very long time. Maybe since 2015 or so, so it may be one of the first ones. PCB reads "UT210E Rev.1"
I hate the backlight going off too soon, and always having to move it to DC, so finding this tweak seems useful. And I had all the stuff like CH304 and clamp already in a drawer, so I thought I give it a try.
Using this video and this specific post as a guideline.
And it all went very well. EXCEPT.... The content of my EEPROM is SOOO much different then the examples shown. None of the BEFORE values in the aforementioned post match.
So I do not dare to make the changes
Any suggestions?
2381607-0
Edit: anyone know how to link a YT video without it immediatly expanding and taking up all space?)
Edit2: Figured it out. Bad USB cable (too long for the CH304, erratic results)
When I plugged the CH304 directly into the laptop, it went correct the first time, all values as expected, all mods worked. (well, I did no test 1000 Amps yet)
« Last Edit: September 24, 2024, 07:08:33 pm by cybermaus »
Offline KungFuJosh
  • TEAS is real.
« Reply #881 on: September 24, 2024, 06:19:33 pm »
Usually the shortened "Share" URLs don't get embedded as the full video.
The following users thanked this post: cybermaus
Offline cybermaus
« Reply #882 on: September 24, 2024, 07:09:10 pm »
Indeed, thanks.
Offline jewelie
  • Everyone's gotta start somewhere
    • Personal website, of sorts, sometimes with a Pi-driven bird-feeder webcam (currently down but will be putting it up again in the near future with IR capability.)
« Reply #883 on: September 25, 2024, 02:02:08 am »
Am I right in thinking this CPC/Farnell TENMA 72-2985 appears to be a UL tested, certified version of the UNI-T UT210E?
https://cpc.farnell.com/tenma/72-2985/clamp-meter-mini-200a-ac-dc/dp/IN07620?st=dc%20clamp%20meters
Anxious newbie to EEVblog.  Resuming an interest in basic electronics after a close shave with a joint EE/Computing degree decades ago
Offline cybermaus
« Reply #884 on: September 25, 2024, 05:42:22 am »
Sure looks like it. Mind you, legal mumbo jumbo not being my forté: Does "conforms to UL" mean the same as "UL certified"
I once had a discussion about IEC-61131, where a device I helped designing "conformed to IEC-61131", but it was never send for certification.
Offline Oszitrek
  • Country: hu
« Reply #885 on: January 31, 2025, 06:16:07 am »
UNI-T UT210E Modifications
ADDR : OLD | NEW
10000 Count (DM1106 chip ONLY, check it!)
10: 70 10
11: 17 27
12: 98 D8
13: 08 27
14: BE D4
15: 00 03
2A Dotless Calibration (Copy values from 50 to 56, 51 to 57)
56: 00 ??
57: 80 ??
2A Modes (1. Dotless DCA, 2. Dotless ACA, 3. Dot DCA, 4. Dot ACA)
87: 17 1C
97: 16 1D
A7: 00 16
B7: 00 17
20A Modes (1. Dot DCA, 2. Dot ACA)
8B: 19 18
9B: 18 19
100A Modes (1. Dot DCA, 2. Dot ACA)
8D: 1B 1A
9D: 1A 1B
Expand 100A To 1000A (DM1106 chip)
07: E8 10
08: 03 27
Extra Modes (1. Continuity, 2. Ohms, 3. Diode, 4. Capacitance)
8F: 07 09
9F: 09 07
AF: 0A 0A
BF: 0B 0B
V Modes (1. DCV, 2. ACV, 3. DCmV, 4. ACmV)
8E: 04 03
9E: 05 04
AE: 00 05
BE: 00 06
NCV, NCV mV
9C: 00 02
AC: 00 1D
Power Off 1 Hour
FB: 0F 3C
Endless Backlight
FC: 0F 00
Low Battery Warning 15Sec
FD: 80 8F
Hi everyone ,
I modified follow page 20, and detect a problems with value of  switch Range up : example 10000 counts , they set address 12,13  =27D8H =10200 mean when DMM counter over 10200 will be switch range , but if voltage measure is 10v so it will show OL on screen , really not good  :-\ . Solution is set switch range up= 9800 and switch range down =960 so we will cover full range , voltage display auto switch range when over 9800 count , ex: 9.700v ->9.799v -> 09.80v -> 10.00v ->50.00v , down 10.00 ->09.80 ->09.70v ->9.600v ->9.500v . should be better
Hello,
You right! This is the good upper and lower range.
UPPER RANGE: 26 48 = 9800
LOWER RANGE: 03 C0 = 960
« Last Edit: January 31, 2025, 06:18:18 am by Oszitrek »
Offline Paul T
  • Mechanical Integrity Design
« Reply #886 on: January 31, 2025, 12:37:45 pm »
I would (and did) use a very small amount of dielectric grease and be done with it.  By adding tape, a non-conductive material is introduced, which can wear much faster than the copper trace would, potentially polluting the contact area.  Also, the edges of the tape have exposed adhesive with can also liberate and cause connection issues.  And tape deteriorates more quickly than the copper and soldermask.
Based on what I saw with mine, the multimeter range selector without modification could last through tens of thousands of cycles without risk of broken traces, but the same cannot be said of the tape or whatever material that is used.  The lower strength soldermask was broken, not the copper.  And now the soldermask over the trace is gone.  Problem already solved.
If they used gold-plated spring contacts, I might feel differently.  You don't want high quality gold surfaces polluted with copper residue.
BTW, my PCB needed really aggressive cleaning due to get rid of a problem where a megohm resistance was detected without leads connected.  It developed this issue after only one year, never exposed to "the elements".
The selector wheel also had stubborn operation and needed pulled apart, surfaces smoothed, and reassembled with grease.  Now I can easily change the range with one finger again.
« Last Edit: January 31, 2025, 12:42:45 pm by Paul T »
Electronics always a hobby, and intersects my career. See my occasional helpful articles at www.keepontesting.com/feed
Offline joeqsmith
« Reply #887 on: January 31, 2025, 03:51:18 pm »
I stopped contributing once Behemot joined and the mods got involved.
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg1048561/#msg1048561
Behemot posted a comment on my YT channel not too long ago.  Guessing they thought I would not remember them.
Later, I did post about some mods I made to increase the BW.   This was a major hack making the probe work my like my vintage Tektronix RF current probe using a separate DC and AC path.
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg1101265/#msg1101265
Seven years later,  noticed your post about the switch failures.   We purchased six or so of these and I have two at home.  I started to see switch failures in the first 2 years.  Most are being used for a current probe only.   So far, I have been able to recover them by cleaning the contacts and have been applying dielectric grease to the ones that have had a problem.
The only one I am aware of that was damaged so far was used to measure the output of a mag on a lawn mower.   I really wish UNI-T had done a better job with this product.  It's been very useful.
Catch you in another six.
Offline cybermaus
« Reply #888 on: March 01, 2025, 04:17:37 pm »
My brother accidentally bought a UT211B after I advised him the UT210E
They sure do look alike.
Since he too plans to mostly use it DC (for his camper) I also managed to mod AC default to DC default, but the UT211B is slightly different.
Mostly the switch position colums are swapped. Here is the original EEPROM, and the mods I made, as well as what I figured out.
Differences (not exhaustive)
Original EEPROM
Modded EEPROM
Also, my programmer image indicates the incorrect chip position, even though it is the same 24C02A
Also do not forget to set the rotary switch in a Amp or NCV position to read/program
