Author Topic: I want to buy my first oscilloscope, help! SDS1102CML+ vs Rigol DS1102Z-E  (Read 613 times)
Offline pantojazapataTopic starter
  • Country: co
Hello everyone!, I am an electronic engineering student from Colombia :D and I want to buy a basic but complete oscilloscope. I'm between 2 options]:
1. SDS1102CML+ ($319)
2. Rigol DS1102Z-E ($279)
Del rigo strikes me that it can decode some signals such as UART and its memory depth of 24 Mpts
Which one do you recommend and why?
thanks!
« Last Edit: May 27, 2023, 06:16:11 am by pantojazapata »
Online BillyO
Have you considered saving a bit more money and getting something like the SDS1104X-U?  It's only about 25% more money for a hugely better scope.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline kcbrown
thanks!
If the choice is between the Siglent 1102CML+ and the Rigol 1102Z-E, it's no contest.  The Rigol is far and away more capable than the Siglent.  They're essentially a generation apart.
You should read the spec sheets for both.  The measurement capabilities alone on the Rigol far outweigh the Siglent, as does the display (intensity-graded), the triggering functions (far more), the math functions (quite a few more), the sample memory (an order of magnitude more), the waveform update rate, etc.
I've had the 1102CML and the Rigol 1054Z (the 4 channel version of the scope you're looking at).  It's no contest between the two.
The following users thanked this post: egonotto, hlj.pycad
