Author Topic: Bricked my Rigol DS4014 after firmware update  (Read 1245 times)
Offline isso
« on: April 19, 2020, 11:43:50 am »
I tried to upgrade my Rigol DS4014 firmware today, downloaded the latest version 00.02.03.02.00 from the official website, copied it to a USB stick, started the FW upgrade procedure which went fine until about 90%, then on "FPGA upgrade" step it got stuck. Waited for about an hour, then turned the oscilloscope off. Now it only presents a black screen at boot. Any idea how this can be fixed? Tried pressing Help button many times during boot - it doesn't do anything. Thanks
Offline isso
Re: Bricked my Rigol DS4014 after firmware update
« Reply #1 on: April 23, 2020, 09:35:54 am »
I tried the FW upgrade a couple more times (by repeatedly pressing Help button during boot while USB stick is plugged in) and finally it somehow went through and now the device is working! FYI
Offline jemangedeslolos
« Reply #2 on: April 23, 2020, 09:41:32 am »
Nice  8)
Offline isso
« Reply #3 on: April 23, 2020, 10:15:28 am »
Hmm, interesting side effect - now in the system settings the device is displayed as DS4054  :-+ !!! However all decoding options disappeared and the "Installed" options menu is greyed out. Device serial also zeroed out. Weird... I'm not going to risk another FW update though.
Offline Electro Detective
« Reply #4 on: April 23, 2020, 10:30:41 am »
Good news so far isso  :-+
one less door stop to trip over :phew:
Any chance the Siglent firmware web pages and info are STILL confusing in 2020 ?  :palm:
Nice scopes, but crikey..   :horse:
Blank Fat32 formatted USB stick  ?
« Last Edit: April 23, 2020, 10:47:31 am by Electro Detective »
Online tv84
  • Country: pt
« Reply #5 on: April 23, 2020, 12:08:51 pm »
I think that shows that it lost its config (serial, model, etc) and rolled back to default (and Rigol is very generous with their defaults).
To regain options menu maybe you have to re-set the model type and S/N.
Offline tautech
« Reply #6 on: April 23, 2020, 10:52:59 pm »
Brand brain fart perhaps ?  |O
Avid Rabid Hobbyist
The following users thanked this post: Electro Detective
Offline isso
« Reply #7 on: April 24, 2020, 07:14:21 am »
@Electro Detective - yep blank FAT32 USB stick
@tv84 - I'm afraid to brick it again, so will keep this as is... I have a separate logic analyzer for protocols anyway
« Reply #8 on: April 24, 2020, 09:46:10 am »
isso, it's not over till the DSO sings
You don't want your DSO to be half baked in digital  limbo land do you?  :-//
Contact Siglent Support and ask them the exact method and file to get your DSO rocking!  :clap:
You've already bricked it and it came back to life, why not try again and get it 100% operational ?   8)
Online 2N3055
  • Country: hr
« Reply #9 on: April 24, 2020, 09:53:12 am »
LOL it's not Siglent it's Rigol...
« Reply #10 on: April 24, 2020, 10:57:05 am »
What a stuff up!   :o  busy reading other Siglent related posts and blundered here big time,
and still rolled with it even after member tautech tipped me off  =   :palm:
« Last Edit: April 24, 2020, 11:00:39 am by Electro Detective »
Online 2N3055
  • Country: hr
« Reply #11 on: April 24, 2020, 11:03:50 am »
Aaah it happens...
That's a nice collection of  :palm:..
Offline Elasia
« Reply #12 on: April 25, 2020, 03:38:31 pm »
Yeah if you dont have a prior backup by hacking it your only option may be to send it in to rigol
First thing i usually do is grab a copy of the os thats running if possible because i like to modify the software of my gear which both rigol and siglent make very easy
Offline isso
« Reply #13 on: April 29, 2020, 10:15:24 am »
@Elasia - is there a way to make a backup of Rigol FW? Could you point to some instructions on how to do it? I wasn't able to find anything regarding this model.
For everyone's info - as I mentioned after the FW update my DS4014 model surprisingly started to get identified as DS4054. I hooked up a signal generator to see if it indeed has higher bandwidth, and to my surprise not only it displayed the signal up to 500 MHz, but it was able to capture it even up to 1200 Mhz!!  :clap:  with a significant amplitude reduction though. Wow I can't believe I have such a powerful device now.
Offline ebclr
« Reply #14 on: April 29, 2020, 01:29:51 pm »
" Contact Siglent Support and ask them the exact method and file to get your DSO rocking!  "
I don't think Siglent will do any help os Rigol's Scope  :-DD
