Author Topic: Ground/earth bridge tabs for Siglent PSU?  (Read 825 times)
Offline bayjellyTopic starter
« on: December 06, 2020, 07:36:02 am »
I've got an SPD3303C (the one with the 7 segment displays instead of the LCD), and it's been great so far. However, whenever I want to connect earth and ground together, I do so shoddily with some wire.
What do you use to bridge them together? Were there maybe some metal tabs in the package that I just didn't notice?
Offline tautech
Re: Ground/earth bridge tabs for Siglent PSU?
« Reply #1 on: December 06, 2020, 07:46:44 am »
No provided links IIRC as these are an isolated output PSU and as such a mains earth connection is not normally used. It's only brought to the front panel for convenience should you need it.
If they're like the X model PSU's the binding posts are cross drilled so it's easy to strap them with a short piece of wire.
Why do you want to strap circuit ground/neg to mains protective earth ?
Offline tautech
« Reply #2 on: December 06, 2020, 08:23:22 am »
« Reply #3 on: December 06, 2020, 10:35:08 pm »
A piece of wire is what I want to replace, since it's in the way and tends to fall out when using the drill holes for other wires.
Because while it's nice to have an isolated PSU, often-times I don't care about the isolation and instead want to have my devices hooked up to it referenced to the same ground as my computer, oscilloscope, and other non-isolated devices. Those will reference the device to earth anyway, and I prefer that to be consistently so, rather than when I, say, hook up the oscilloscope probe ground clip.
These are probably what you seek:
https://www.pomonaelectronics.com/products/hardware/shorting-link-binding-posts
Those look like they'll do the job, thanks.
