Author Topic: power FINSRI 1014D  (Read 461 times)
Offline lagonbleuTopic starter
power FINSRI 1014D
« on: January 14, 2023, 02:29:27 pm »
HI , and good year !
Hello everyone I make a mistake when i put  12v power DC  on finsri 1014d :
Because i don't have US adaptator , then i use 5v DC but nothing !!!
With 12v  ok ,but after some tests  , lights freeze and commands  inopĂ©rante  ....
I found Chip HS (burns )  :  TS 61041   (U15)  TEXAS INSTRUMENT ?
I want  to change bus this is CMS 6 broche . I find only 5 broches ...
Does anyone  can tell me where i  find this ?
very thanks* Schematic_Scope 1014D_2022-05-10.pdf (884.84 kB - downloaded 28 times.)
Offline pcprogrammer
Re: power FINSRI 1014D
« Reply #1 on: January 14, 2023, 03:30:34 pm »
According to the datasheet you can probably also use the TPS61040. Has a higher internal switch current limit, so not sure if that will be a problem.
https://www.ti.com/lit/ds/symlink/tps61041.pdf?ts=1673695286067&ref_url=https%253A%252F%252Fwww.google.com%252F
It is always a risk when buying of Aliexpress. Here is a link to a shop selling them.
https://nl.aliexpress.com/item/32965120446.html
