Author Topic: ESR meter  (Read 2755 times)
Offline janengelbrechtTopic starter
    • JP-Electronics
ESR meter
« on: February 19, 2024, 07:23:15 pm »
I have built an incircuit ESR meter based on arduino.
My only problem is calibrating it.
I only have the AVR component tester from ebay TC-7. And we all know it isnt really that good.
Is there some industry standard methods to measure ESR with an oscilloscope, tonegenerator and perhaps a few components ?
« Last Edit: February 19, 2024, 07:28:05 pm by janengelbrecht »
Offline xtech
Re: ESR meter
« Reply #1 on: February 19, 2024, 07:52:45 pm »
Use resistor, then measure unknown capacitor and check if adding same resistor in series with capacitor changes reading by proper value.
« Last Edit: February 19, 2024, 07:55:21 pm by xtech »
Offline pqass
Re: ESR meter
« Reply #2 on: February 19, 2024, 08:34:25 pm »
Not industry standard but useful still...          calculations shown at 11:53.
Offline kripton2035
Re: ESR meter
« Reply #3 on: February 19, 2024, 09:23:02 pm »
I would use a simple small value like 1Ω resistor, it would be more than close to the real result, and enough to test if a capacitor is good or not.
I also have resistors to 50mΩ to check my esr meters ...
