Author Topic: KP184 time current curves (melting fuse time curves)  (Read 1133 times)
Offline SharpTopic starter
« on: August 15, 2021, 07:16:25 pm »
Hi Guys
I have a KP184 and need to verify the current accuracy for some PCB fuses.
I have only used the KP184 a couple of times, and only used the load testing, using the constant current function.
I need to do a couple of “time current curves” (melting fuse time curves) with constant current load over time.
Any suggest to how I approach this task ?
« Last Edit: August 15, 2021, 07:19:39 pm by Sharp »
Offline Kean
    • Kean Electronics
Re: KP184 time current curves (melting fuse time curves)
« Reply #2 on: August 31, 2021, 02:47:34 pm »
Thank you Kean
