Author Topic: Brymen 869s + BU-86X not recognized in some OS and some applications  (Read 436 times)
Offline le_avionTopic starter
Executive summary:
Brymen 869s and the BU-86X interface
** on Windows with the supplied software: no go.
** on Windows with Test Controller: works.
** on Linux with Test Controller: no go.
Details below.
I just got my Brymen 869s and the BU-86X interface.  I also installed the included (seems antique) software on Windows 11.
Tried to link to the DMM but I am getting a "USB adapter cable not found" error even though the DMM appears in the devices list as Superior DMM.
Then I installed Test Controller in the same Windows 11 machine and it had no problem finding and connecting to the DMM.
Now I try on my main Linux machine, a POP OS (based on Ubuntu) with Test Controller but it fails here and I am not sure why.
Here is the log:
;; jSerialComm version: 2.10.3
;; Start thread for: HIDv0820p0001 - Brymen BM869s
;; HIDv0820p0001: Found HID: 046D C332  30 36 36 31 33 36 35 38 33 39 33 33
;; HIDv0820p0001: Found HID: 065A 0001  48 30 30 31
;; HIDv0820p0001: Found HID: 0820 0001  11 3F 02
;; HIDv0820p0001: Found usb device: /dev/hidraw8
;; HIDv0820p0001: Rx: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
;; Stopping thread for: HIDv0820p0001 - Brymen BM869s
;; Use "Load devices" page for selecting devices to load. Most devices will only load if they are connected and ready.
As you can see it starts a thread for: HIDv0820p0001 - Brymen BM869s
and then stops the thread for: HIDv0820p0001 - Brymen BM869s
My Java version is java "17.0.1 2021-10-19 LTS"
Is it a permission issue, something else? Any suggestions?
« Last Edit: October 30, 2024, 06:00:08 am by le_avion »
Offline BILLPOD
Re: Brymen 869s + BU-86X not recognized in some OS and some applications
« Reply #1 on: October 30, 2024, 07:02:24 pm »
Good Morning Le_avion,   My BN869S has been connected to my laptop for a couple years now and has worked from the get-go with the BU-86X interface.   My laptop is using Windows 10.   So maybe your issues have to do with the difference
in the versions of Windows. :-//
Offline chronos42
« Reply #2 on: October 30, 2024, 08:15:41 pm »
I have longer time not used the interface and the (indeed antique looking) software. For testing, I plugged in the USB adapter, started the software, linked the meter, and it works perfect under Windows 11 24H2.  :-//  I also never had Problems with Windows 7 and 10 in the past.
Offline Furna
  • I still don't know
« Reply #3 on: October 31, 2024, 07:13:05 am »
Have a look at https://www.eevblog.com/forum/projects/brymen-bc-86p-usb-adapter-firmware-with-usbtmc-scpi/
The latest release of the BM869s doesn't work out of the box with BU-86X adapter.
Various work around are present in that post:
- simple sheet of paper between the adapter and the DMM
- replacing a resistor on the adapter
- replacing a resistor on the DMM
- replacing the firmware on the adapter
I guess you can start from the simplest one and then make a choice
Let us know the outcome.
Thank you.
PS I found Pulseview from Sigrok project the easiest way to log data from the BM869s.
Unfortunately I am on a travel and don't have the command line ready at the moment.
« Last Edit: November 05, 2024, 05:58:48 pm by Furna »
The sky above the port was the color of television, tuned to a dead channel.
« Reply #4 on: October 31, 2024, 06:15:38 pm »
Thank you for your reply.
I not sure it is the same issue because I found that the adapter and DMM combination works fine under Windows 11 with Test Controller but the same combination fails under Linux. That's why I was wondering if it is a permission issue but I didn't find any error messages in the Linux logs.
