Author Topic: Brymen bm235 continuity voltage  (Read 2301 times)
Offline xrogersTopic starter
« on: September 28, 2016, 09:49:58 pm »
Hi All,
I need to do some continuity testing on a broken PCB, but my old meter is both slow and too high voltage (about 5v). I can't find either the continuity voltage or maximum current specs for the bm235 in the manual or in web searches.
Can someone who knows tell me these numbers, or check their meter and tell me?
Thanks!
Buck
Offline TheSteve
  • Living the Dream
Re: Brymen bm235 continuity voltage
« Reply #1 on: September 28, 2016, 10:03:00 pm »
Why not measure it with your older meter?
VE7FM
« Reply #2 on: September 28, 2016, 11:27:25 pm »
I don't own the meter, I'm considering buying it and want to be certain it'll work for me.
Thanks,
Buck
Offline IanB
« Reply #3 on: September 28, 2016, 11:30:26 pm »
I can measure it later after I get home, if nobody else answers sooner.
Offline joeqsmith
« Reply #4 on: September 28, 2016, 11:51:13 pm »
Hi All,
Thanks!
Buck
It's all in the spreadsheet.
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/
« Reply #5 on: September 29, 2016, 12:53:20 am »
Exactly the info I was looking for, thank you! And thanks also for the offer to check.
Offline retiredcaps
« Reply #6 on: September 29, 2016, 01:40:21 am »
Specs are right in the manual.  Page 23
http://www.eevblog.com/files/BM235-Manual-EEVblog.pdf
Diode Tester - Test Current: 0.3mA typical
Open Circuit Voltage: < 3.2VDC typical
Ohm -
1)Open Circuit Voltage: 1.6VDC typical
2)Constant Test Current: 0.2uA Typical
3)Constant Test Current: 0.02uA Typical
In most meters, lowest ohm range (600) is the same as continuity.
I also listed the diode test because some people use that to check for shorts.
Offline IanB
« Reply #7 on: September 29, 2016, 03:20:10 am »
On my meter the open circuit test voltage for continuity is 1.71 V and the test current is 162 µA. These match closely with Joe's measurement on his meter.
