Author Topic: Fluke 91 Series II?  (Read 463 times)
Offline wd5jfrTopic starter
Fluke 91 Series II?
« on: January 18, 2023, 02:51:10 am »
Bought one at a hamfest and it should be useful.  Works well on all the functions I've been able to test (confirmed with my Fluke 189II)  but I'm curios why I  have to use a scope probe to measure voltages over 3 volts rather than the regular test leads or am I using it incorrectly?  It didn't have a probe so I'm using a Tektronix P6100 and it appears to be making  connection with the red non-metallic BNC input.  If using the recommended PM8918 probe is better I wonder if anyone has a surplus one for sale and also interested in a DEMO BOARD and protective  surround case.
Thanks
Hank
Offline bdunham7
Re: Fluke 91 Series II?
« Reply #1 on: January 18, 2023, 03:28:46 am »
The banana jacks are intended for ohms, diode, continuity, temp and external shunt functions.  All normal voltage functions are through the BNC connector with a suitable probe.
https://assets.fluke.com/manuals/scopemt2umeng0000.pdf
