Author Topic: Brymen vs bench top multimeter  (Read 5399 times)
Offline robdejongeTopic starter
  • Country: th
« on: March 27, 2023, 01:26:55 am »
Many years ago I bought a $5 meter 'just so I had one'.
Then I got into playing with electronics and to get a 'decent' meter I got a Holdpeak HP-770D. It did the job for a few years, but it has been behaving oddly of late and I've decided to just get it out of the way and buy "a serious meter". I landed on Brymen, and picked the BM867s model for its insane value for money.
While browsing 'similar price' multimeters on the shop I'm buying from, I saw the Owon XDM2041. And then I saw the UNI-T UT8804E which would be a real splurge but does really look the part without becoming silly for a hobbyist like me.
I've always wanted a bench top multimeter. But the depth is just a real challenge. I'm lucky enough to have carved out a space as a dedicated bench, but it's only 60cm deep and these things are massive. Shelves overhead can't accommodate. So I'd have this great big honking meter on the main surface ... and I'm just wondering .... is that the right decision?!?
I've always liked (reading and getting) the feedback of this forum, so I thought I'd throw this out there and ask you guys what you think about such a decision. When to get a bench top, how valuable bench top space is, etc.
(Although my main point is above, also welcome comments comparing those exact meters. As an aside, I did look at the XDM1041 / 1241 a long time ago but for some reason decided not to get it even though the form factor would be ideal for my setup. There was something about it I didn't like, although I can't recall what it was.)
Thanks all!
(update: is it maybe that "you get a bench top meter only when you want to be able to do 4-probe measuring"?)
« Last Edit: March 27, 2023, 02:30:07 am by robdejonge »
Offline Fungus
Re: Brymen vs bench top multimeter
« Reply #1 on: March 27, 2023, 03:06:58 am »
I vote "no".
Online 2N3055
  • Country: hr
« Reply #2 on: March 27, 2023, 05:34:23 am »
What do you need it for?
There are bench multimeters that do not have 4W resistance measurements.
Bench multimeter is a form factor.
They mostly work with external power so no need for batteries.
- that is good because if you work a lot you will use a lot of batteries otherwise. Or battery will die when you need it.
- that is bad because you need electricity for it to work, where you work.
There are bench meters that have high precision.
- if you don't need higher precision or 4W ohms than it doesn't matter.
You can put them on the shelf so you clear up desk space..
- If you can't put it out of your way, than it will take more space.
If I were you I would rather buy an LCR meter, like DER-EE DE-5000, if you don't have one. You already have excellent meter that is more than enough for professional work. And LCR meter is a very useful instrument, for instance. Just another meter that will give you nothing new is not something useful.
Sometimes few cheap meters are also useful when you need to measure several things at the same time. etc etc..
This is just one of those questions where people are not sure what to do. And truth is nobody can decide for you. Everybody have some limitation on resources (money, desk space, number of equipment before their wife divorces them etc.), different needs (some work on this some on that, and some people simply collect T&M equipment instead of stamps) and wishes (everybody wishes 8.5 digit handheld multimeters with 0.001% error LCR meter built in. Or 4 GHz scopes. While in reality, DER-EE DE-5000, BM867 and 1000 series AWG and 1000 series scope from Siglent or Rigol are good enough for lots of pro work).
So any time you have an itch to buy any new piece of T&M equipment (or tool or something) ask yourself:
- Do I NEED it? As in: I cannot repair this because I need to measure this and none of my instruments can do it.
- Would it help if I had one? As in: If I had this it would save me time when I repair this and that. And since I do that a lot...
- Can I afford it? Will money I give for it be worth it in some way (whatever that means. Some people buy expensive cars because they simply like it, not really need it..) Will I use it enough for it to be worth it? Or shall I just borrow or rent something occasionally..
- Do I have resources needed to use it?  As in: space on desk, space in a shop, water, electricity etc etc.
« Last Edit: March 27, 2023, 05:55:25 am by 2N3055 »
Dr. Richard W. Hamming
The following users thanked this post: Performa01
  • Country: th
« Reply #3 on: March 27, 2023, 07:31:09 am »
I don't need that level of precision. I was just wondering if that is the main reason people opt for bench meters.
You mean the Holdpeak? It was fine when it worked, but I've grown frustrated with it.
This is a fair comment. I was merely asking for thoughts though, as sometimes others will offer arguments I would never have thought of myself. Or, in this case, where specific models were listed, that might have triggered some comments. In the end, you're right, I'll always have to make the decision myself. But I take your point that it might be too vague a question. Or maybe even too specific, maybe I should have asked "what are the arguments for/against bench top, in general?"
Appreciate you taking the time to write up the response. Thank you.
Offline tooki
« Reply #4 on: March 27, 2023, 07:47:44 am »
I have a Keithley 2015 and a few Keithley 197 bench meters.
4W ohms for measuring small resistances is the only thing I ever use in my bench meters that my handheld meters really can’t do. I almost never need extra precision. While it’s very… gutturally satisfying to see 230V measured to the millivolt, nothing I have ever done actually requires anything of the sort.
Another thing I love about the Keithley 2015 is its speed: it’s just insanely fast. For most things, you’re simply never waiting for the reading to settle. Put the probes on a voltage source and the voltage reading is just… there, before your eyes have even had time to refocus on its display. Again, in no way necessary, it’s just nice. The 197 is much more ordinary, with 3 readings per second, similar to most handheld meters.
The last thing that I really like about the K2015 is the display. As a vacuum fluorescent display, it’s just easier to read than an LCD.
And of course, the other advantage of a bench meter is that it can just be there out of the way, yet ready to use. I don’t have to grab and stand up a handheld meter, and the buttons let me operate it with one hand (unlike the knobs on many handhelds). But for this you have to have the space for it. My bench is 90cm deep, and even with that it feels cramped!
  • Country: th
« Reply #5 on: March 27, 2023, 08:32:14 am »
Some good points in there, @tooki ... thanks for the response.
Online donlisms
« Reply #6 on: March 29, 2023, 02:04:34 am »
I don't know if this will help; it's what I did.
My bench is 60cm deep.  My shelves are the posts-and-adjustable-wire-shelf variety, 30cm deep.  I didn't want them covering half the bench, and I didn't want them far away, taking up so much room behind the bench.  The solution was...  half and half.
With a little creative assembly, the front posts are shorter and sit on the bench, and the back posts sit on the floor.  The depth of the shelves is split between the bench and the floor; the bench has to be pulled away from the wall a little.
The things on the shelves do not get in the way.  Bench DMM's fit fine - it's okay if they hang off the front of the shelf a few cm; no harm is done.
Best of all, I could buy all the shelf parts, instead of adding another construction project to the Todo list!
Offline GigaJoe
« Reply #7 on: March 29, 2023, 03:06:59 am »
stand for my handheld  ;  wide triangle,  to avoid fell off , really like it , high should be enough to hook by rear arm of multimeter ,  it fixed by tape , and width enough to avoid falling on side  :)
  • Country: th
« Reply #8 on: March 29, 2023, 04:47:48 am »
For my specific setup, with a work space just 60cm deep and shelves just 25cm deep, no real bench meter seems to be workable. Just 10cm above my workspace floats a 13cm-deep shelf on which I sit things like my scope and quick access tools. I love that setup as it clears the surface but keeps things nearby.
For that small shelf, I thought the Owon XDM1041 would make a perfect solution. Nothing like a real bench meter, but looks a bit more 'in place' than a handheld meter in that setup. But call me OCD, the oddities covered by many of this meter when it first came out (1-2 years ago?) still seem to not have been addressed in firmware updates and so I just decided to steer clear of it.
So, decided on getting the Brymen in the end.
Thanks all for the comments.
The following users thanked this post: tooki, 2N3055
Offline paulca
« Reply #9 on: April 06, 2023, 06:20:16 pm »
(waves)
I'm in nearly the same boat.  Although I bought the BM235 already.
I still want a bench meter.  The OWON's look like the right budget.  However I have made that mistake with scopes twice too many.
I don't need a "I paid $3500 reference" meter.  I don't even think I need a "I paid $350 for second hand reference" meter.  I wouldn't know how to test it was accurate.  Chicken and egg.
Why a bench meter?  The opposite reasons to "Why handheld.".  It can't move.  It doesnt have batteries.  It's always there and it's never just powering off on you to save battery.
However.  For what I could spend on a "Brand" bench meter, such as a Siglent circa $800 I could get 4 Owons.
That actually appeals to me more.  There are DC things I'd love not to waste a scope channel on.
I think the only non-basic features I'd say were a must is statistics.  Max,Min,Mean,Hz,Duty stuff in small print measure or by button if it must.
UART/USB/Serial do-dah would be nice, but I bought that option on all three bench supplies and I think I tested only one of them.  I found the other two BT modules in the parts bin.  It's not that the one I tested was bad, the Tenma, you could set it to CSV output and it would run it's values out at about 10Hz or something.  That's actually quite useful.  It would also accept parameter changes, allowing for "remove control" from an MCU.
Part of me just wants a strip of bare bones volt meters with mini-hook-clips hanging in a row on the bench shelf.  Maybe not the $4 LED volt meters, but I'm still looking for middle ground.  Mend-it-mark has tempted me to go retro with actual swinging analogue gauages.... shame it's one range per gauge :(  But ... no.  I like my digital and I like my software features and color LCD screens. I'd take that over a 5th digit decimal on volts (10uV).
The other option is to buy 6 $20 hand held meters and hang them from their stands on a wire.  Playing servant to their power saving would not be much fun.
Offline nctnico
« Reply #10 on: April 06, 2023, 08:05:10 pm »
Buy the Vicy VC8145 and be done with it.
Offline nightfire
« Reply #11 on: April 06, 2023, 09:25:41 pm »
I also had the same thoughts, as I equipped my bench. Long story short, I have two bench meters, bought used on ebay in good condition.
Advantages of a bench meter, that mattered to me:
- no batteries could go bad, empty or leak
- no powersaving shutdown
- illuminated display, AND no powersaving 15 seconds or so for no illumination again
- higher precision for same price
- stackable
I ended up with a Fluke 8600a and Fluke 45, which are more than good enough for what I am measuring. Of course, with some drawbacks, like no autoranging on the 8600a, but when you know what you are doing, autoranging in lots of cases is not needed.
I personally would try not to get those fancy bench meters below 200 $/€ - in most cases they are simply handhelds fitted in a case and then sold as "bench", so you get only the better power supply.
Offline nctnico
« Reply #12 on: April 06, 2023, 09:34:26 pm »
Why not? Your reasoning makes absolutely no sense to me. In the end not having to swap batteries and being able to leave it on all day is a major comfort improvement well worth the money. For bench use I'd take any bench meter with a power cord over any handheld just for the comfort. I could not care less about what is inside; I want the bench functionality.
« Last Edit: April 06, 2023, 09:43:38 pm by nctnico »
The following users thanked this post: robdejonge
Offline nightfire
« Reply #13 on: April 06, 2023, 09:44:48 pm »
The value of those cheap bench meters is... IMHO not very good. Here some used buy for nearly the same money will probably provide better value.
I got my Fluke 45 (calibrated) for 250 Euros, and have a reliable instrument.
But yes, I agree- when bench function and lack of batteries is the prime aim, then those cheap bench meters will fit the bill.
But as a good quality DMM is available, I would consider it as a waste of money to buy for similar money some bench DMM with significantly poorer performance.
Offline nctnico
« Reply #14 on: April 06, 2023, 09:50:56 pm »
But that is the kicker: the VC8145 has more features, better accuracy for AC true RMS compared to the Fluke 45. And after a decade of sitting on my bench it is still bang-on because it is built around a good quality voltage reference. It is a fallacy to think the old meters are somehow better. They are not. Extremely outdated is the term I'd use. I have fallen into the trap thinking that old equipment is somehow better one time too many and kept my eyes open since then. When I look for test equipment I dig deep into the specs & reviews and think long & hard about what actually brings me value for my money.
« Last Edit: April 06, 2023, 09:56:46 pm by nctnico »
Offline BeBuLamar
« Reply #15 on: April 06, 2023, 10:55:09 pm »
If I buy a bench DMM it would cost many times the Brymen. I don't think i want bench DMM which costs about the same a Brymen.
Offline nctnico
« Reply #16 on: April 06, 2023, 11:28:27 pm »
You know that is like saying you prefer to use a bicycle because if you'd buy a car, you'd buy a Ferrari sports car (which actually isn't practicle for daily use).  >:D
« Reply #17 on: April 06, 2023, 11:36:48 pm »
Horse for courses !
Precision or convenience are in vastly different budgets.
  • Country: th
« Reply #18 on: April 07, 2023, 01:23:35 am »
I've often considered building this myself, for when you have multiple spots in a circuit to monitor and resolution is not really a big deal. I'm glad to find I am not the only one thinking these crazy thoughts!
Offline Fungus
« Reply #19 on: April 07, 2023, 01:34:58 am »
But that is the kicker: the VC8145 has ...
The VC8145 has no uA range.
« Reply #20 on: April 07, 2023, 01:59:10 am »
That you certainly will need for any modern uP project.
Offline nctnico
« Reply #21 on: April 07, 2023, 09:09:26 am »
Actually it has but it is called 'mA range' that goes down to 1uA resolution.
A low end DMM is pretty much useless. Hint: burden voltage
You'll need a specialist device to measure current going into low power devices in order to measure the current peaks correctly.
« Last Edit: April 07, 2023, 09:15:44 am by nctnico »
« Reply #22 on: April 07, 2023, 09:31:06 am »
Agreed however for something that only wakes occasionally measurements of quiescent consumption are as important as anything else.
If real low that Joulescope would be the way to go.
Online RAPo
« Reply #23 on: April 07, 2023, 12:12:18 pm »
Is there any way you can try a bench meter for a while?
I have an Owon XDM2041 but guess what: I use my handheld meters more often, just a tad more flexibility.
Did you have a look at Aneng AN999S? Very compact, needs 5.3 inches of depth and gives you music. ;D
Offline BeBuLamar
« Reply #24 on: April 07, 2023, 01:11:03 pm »
Not what I said. For the money that about the price of the Brymen meter I would choose the Brymen not a bench meter. So yes I would choose the bicycle rather than a car that cost the same as the bicycle. But typical car price isn't the same as a bicycle nor a a typical bench meter is the same as the handheld meter.
For the money of the Brymen which I assume less than $400 I don't think one can buy an new decent bench meter for that. I don't think the OP meant to get a used one. Yes a Brymen in that price is a very good meter.
