Author Topic: BSIDE 09 and 07, 2ch handheld DSO+DMM, claimed 50/25MHz (August 2024)  (Read 1423 times)
Offline tunkTopic starter
  • Country: no
Two new models, BSIDE 09 and 07:
- claimed 50MHz (07: 25MHz)
- sampling rate 250MSps (07: 208MSps)
- dual channel
- 20mV-10V/div
- 100ns-20s/div
- 4" screen, portrait, 480*320 pixels
- size 217*85*36mm, weight 384g
- DMM 6000 count
- signal generator, 7 curve types, 2MHz
- current price a bit below US$80
https://www.aliexpress.com/item/1005007307834964.html
« Last Edit: August 01, 2024, 02:30:01 pm by tunk »
The following users thanked this post: elantric
Offline RAPo
Re: BSIDE 09 and 07, 2ch handheld DSO+DMM, claimed 50/25MHz (August 2024)
« Reply #1 on: August 01, 2024, 02:27:01 pm »
I've ordered the O9. It should be in later this week.
  • Country: no
« Reply #2 on: August 01, 2024, 02:55:20 pm »
Just found this video by 12voltvids released two weeks ago:
https://youtu.be/NqCQ6o-D0ro
Offline RAPo
« Reply #3 on: August 03, 2024, 12:28:31 pm »
The O9 is in.
Look&feel/leads/case: very nice
DMM: nothing really bad, nothing really good
FG: This is not good. The amplitude is always positive, although the drawing of the selected waveform suggests otherwise. If you set a frequency of 0Hz in a sine wave, it will, in fact, switch to a high frequency. You cannot use FG and an Oscilloscope together.
Oscilloscope: cumbersome workings: In OSC mode, you see a menu called Cursor/Measure, but you must "open" this functionality in the channel menu before anything happens. Auto mode is really slow and often misses the signal. The screen can only be saved as .bmp, with no waveform saving.
More tests to follow but for now the Zoyi-703 is much better.
Offline wilfred
« Reply #4 on: November 28, 2024, 01:15:48 am »
I was looking around for a few days and saw this one on AliX almost by accident. I saw the 12voltvids YT review but there isn't much else to be found. And then found my way back here to see if there was any discussion on it. I did see a Bside  branded 702S which was strange.
I like the form factor of this scope and the silicone shield it has. I want it for working on the car and the vertical aspect and not being slippery hard plastic might make tucking it into position easier. No stand is less of an issue.
I liked the review of the Bside 01 linked in this thread https://www.eevblog.com/forum/testgear/new-handheld-scopedmm-bside-01-1ch-10mhz48msps-(nov-2023)/msg5490670/#msg5490670
Is there something similar for the Bside 09/07?
There are always oddities you may not find in reviews. But I'm also tempted by the touchscreen 02 version.
Give me some things to help decide. Please.
