Author Topic: Tektronix PS2520 triple output power supply repair and calibration  (Read 3755 times)
Offline feedback.loopTopic starter
Check out this video. These supplies aren't bad at all. Two channels 0-36V up to 1.5A, the third channel 0-6V up to 3A. I saw good ones on eBay for less than $150.
It turned out this supply needed a fuse, a DAC, and a calibration.
https://youtu.be/q3bn7r77yDY
The following users thanked this post: Falkra
Offline siggi
Re: Tektronix PS2520 triple output power supply repair and calibration
« Reply #1 on: November 29, 2015, 04:11:01 pm »
I recently bought one of those. Mine needed a lot of TLC.
There was shorted logic on the display board, which took out the rectifier and fuse. Some of the optos weren't making grade on the current transfer ratio, and didn't make the logic thresholds on the far end. There was a broken schmitt trigger on one of the channels, and all the DACs were bad (shorted gate to source).
I found it ... interesting .... to find damage across all four galvanically isolated domains in the thing.
Sent from my iPad using Tapatalk
Offline Len
« Reply #2 on: November 29, 2015, 05:29:25 pm »
At 11:05 do I see you using an unlicensed copy of DaveCAD(TM)?  :-X
DIY Eurorack Synth: https://lenp.net/synth/
« Reply #3 on: November 30, 2015, 08:36:21 pm »
Sounds unbelievable. What are the chances of so many components failing at the same time? It must have been struck by lightning.
Offline siggi
« Reply #4 on: December 01, 2015, 02:19:40 am »
Yeah, go figure.
It didn't look like it had been repaired or boards swapped either. All the pass elements were fine, and it calibrated right up after I fixed that litany.
