Author Topic: BSIDE ESR02 Pro Transistor Tester (teardown & quick test)  (Read 46374 times)
Offline sorenkirTopic starter
« on: January 04, 2018, 04:58:04 pm »
Hello,
I have bought this small device ($22 shipped):
It is cute (wine red box, as stated on the box, I like that  ;) ) and well thought: external 9-12V DC jack, test probes jacks, SMD socket, plug-in sockets, discharge resistor, ESR chart (on the back).
The two buttons have the same function: for left & right handed :-DD.
A few additional functions:
The most useful is the "continuous" capacitance/ESR meter (C+ESR): no need to press the button for measurements.
Even a decent "user manual" is provided:
Don't turn it on, take it apart:
Atmel MEGA328P, LM339 comparator, AMS1117 3.3V & HT7150-1 5V LDO regulators:
Quick test:
330? resistor:
10mH inductor:
SMD 1mH inductor:
White LED:
470 uF capacitor:
Transistors:
Not impressed by a big power NMOS:
No accuracy specification but measured values roughly agree with other instruments I have. Ideal for component identification.
Michel.
The following users thanked this post: edavid, elecdonia, horo
Online Gyro
Best Regards, Chris
Offline CustomEngineerer
Re: BSIDE ESR02 Pro Transistor Tester (teardown & quick test)
« Reply #2 on: January 05, 2018, 02:29:58 am »
Hopefully didn't cost more than $20.  :-DD
Offline doctormord
  • Country: cx
  • !nop
    • #fine_arts & #electronics - 360customs.de
« Reply #3 on: May 18, 2018, 02:51:00 pm »
I find it a quite neat interpretation of the original "Komponententester" by Karl-Heinz Kübbeler.
I made one myself in the past:
http://www.360customs.de/2013/12/transistortesterkomponententester-das-universalgenie/
Tooling yourself a nice (handheld) case isn't normally achieved at $20, so the price looks good to me.  :box:
Regards, doc
#fine_arts & #electronics  - www.360customs.de
Offline precaud
    • LinearZ
« Reply #4 on: May 19, 2018, 01:25:48 pm »
[snip]
Likewise. I picked one up a couple months ago and have found it to be well executed and quite useful.
Offline dirtcooker
« Reply #5 on: August 18, 2018, 09:02:40 pm »
I just bought one of these from Amazon, and the build quality is very good. Software is v 1.11 I've tested a variety of components, and the results are reasonable close to values obtained using my Fluke DVM.
Has anyone been able to measure coil Q and L via sampling (putting a calibrated capacitor across the coil) with this meter? I've tried a variety of L and C combinations and the meter always returns only an Ohm value, as if a resistor were being measured. Calibration step 13 (connect capacitor to pin 1 and 3) is present, so evidently the tester is configured with the samplingADC function.
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #6 on: August 18, 2018, 09:38:26 pm »
That's the rugged version of the ESR tester and the ATmega 328 is present has well. Will it hold some bumps? Or has some input protection??
If one can make knowledge flow than it will go from negative to positve , for real
Offline rhb
« Reply #7 on: September 22, 2018, 02:04:50 am »
I just got one of these.  I'm fairly impressed.  I notice that the reviewer and I used a 2N3906 and got similar numbers.
Does anyone know how compatible with the other generic 328 based testers these are?  It would be nice to have  source code for the device even if it's not the factory software.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #8 on: September 22, 2018, 02:19:37 am »
Nice designer color they chose - "Wine Red".  ^-^
Offline precaud
    • LinearZ
« Reply #9 on: September 22, 2018, 04:05:54 am »
Powered mine up a couple days ago, it only shows a blank white screen after pushing the Test buttons to null the leads. I was fairly happy with it up till then. Probably not worth trying to repair... sigh.
Offline indman
  • Country: by
« Reply #10 on: September 22, 2018, 07:37:01 am »
I already showed an new firmware which is suitable for a clone in this topic.
BSideESR02 has no protection of measuring ports! If you have connected the capacity which had a charge, then the processor it is necessary to replace with new. :)
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg1495258/#msg1495258
« Last Edit: September 22, 2018, 07:43:38 am by indman »
The following users thanked this post: 001, Marco1971
Offline 001
  • Country: aq
« Reply #11 on: September 22, 2018, 07:45:14 am »
Thanx a lot
Is it actual firmware version for Bside?
Offline indman
  • Country: by
« Reply #12 on: September 22, 2018, 08:01:31 am »
001,yes! :)
Offline 001
  • Country: aq
« Reply #13 on: September 22, 2018, 08:32:06 am »
is bside unit good variant of marcus design?
Offline indman
  • Country: by
« Reply #14 on: September 22, 2018, 08:39:46 am »
I have collected an firmware only for the Karl-Heinz 1.13k version. I think that there are no obstacles to use the version 1.33m Markus.  :)
Offline 001
  • Country: aq
« Reply #15 on: September 22, 2018, 08:43:39 am »
What did You mean? Is factory firmware for BSIDE so old?
Offline indman
  • Country: by
« Reply #16 on: September 22, 2018, 08:52:27 am »
The Chinese firmware of BSideESR02 is based on the version 1.11k  Karl-Heinz!
It is already quite outdated firmware which has no new opportunities of the version 1.13k.
The following users thanked this post: 001, elecdonia
Offline 001
  • Country: aq
« Reply #17 on: September 22, 2018, 09:57:53 am »
Sorry
Is BSideESR02 is ONE chineese version housed in fabric-made enclosure?
Offline precaud
    • LinearZ
« Reply #18 on: September 22, 2018, 12:12:45 pm »
Yes, I always discharge capacitors before testing. But I wasn't testing capacitors last time it was used - I was sorting thru a box of pulled transistors,  separating FETs from BPs. It's quicker than looking up the numbers  :)  So this failure is unexpected.
Offline indman
  • Country: by
« Reply #19 on: September 22, 2018, 12:37:31 pm »
Sorry
This clone can have the name chineese version DTU-1701. They are identical on an firmware and a hardware stuffing. :)
I don't find any serious obstacles not to manage to repair this device. The scheme is rather simple in understanding if to study a detailed manual from dear Karl-Heinz. :)
Offline 001
  • Country: aq
« Reply #20 on: September 22, 2018, 12:58:39 pm »
Sorry
Thanx
I`m looking for version with BIG monochrome display for my old eyes
Any ideas?
Offline indman
  • Country: by
« Reply #21 on: September 22, 2018, 01:12:25 pm »
I have also weak eyes therefore I have here such clone with the big monochrome blue display!
https://ru.aliexpress.com/item/Free-Shipping-New-12864-LCD-Transistor-Tester-Capacitance-ESR-Meter-Diode-Triode-MOS-NPN-LCR/2044590569.html? spm=a2g0s.9042311.0.0.274233edI9VCwo
But he has no case. :D
Offline all_repair
« Reply #22 on: September 22, 2018, 02:16:01 pm »
My piece failed not long after I got it, but I was testing some uncharged cap .  After putting a new chip, so far it has been lasting quite a while.  I am suspect the original chip might be 2nd rated part.  I don't and can't  fault them at such a low price they are selling.
The following users thanked this post: precaud
Offline precaud
    • LinearZ
« Reply #23 on: September 22, 2018, 02:26:05 pm »
Interesting. I wonder if there's a difference between DIP and flat pack packages in this respect?
Offline rhb
« Reply #24 on: October 04, 2018, 03:20:05 am »
How does one do a FW update?  Is there a pinout for J6 somewhere?
I can think of lots of features to add such as Vbe at Vce_sat.
